Mark Harris
Pain in the ass
tick tock, tick tock...
kplo said:USLatinContent,
Since you're familiar with the OC forums: Can you OC a dual core E6600 to 3-3.5GZ without much trouble on say, a DS3 board? I'm just wondering what would be "safe" with stock cooling.
Thanks for your help.
Ken
the Screen Skins guy
Kholi said:Tell me about it. I have thin fingers so I didn't bother removing the motherboard to bolt it down, but I'll have to do that today because my temps are innacurate.
USLatinContent said:My Thecus is working and the drives get sooooooo hot!!!
The air-flow in it is bull-s!@#$...
USLatinContent said:I believe I said something about cases in the beginning didn't I? lol
All Duos are rated at 61C by Intel but if you know for sure that Quads are rated higher (must be from Intel's site) then you'd want to stay at 60C LOAD... I am quite positive they are rated the same though.
If you can RMA that nice cooler of yours and get a Tuniq you might be in a different ball game because the TT blows wither up or towards the back and aligns the air-flow with most case fans... that way you don't raise the case temperature...
Take a look at your video-card's exhaust, if the fancy cooling on it doesn't dump any hot air into the case you should be glad cause those get way hotter... if not look at PCI-slot blowers like the Antec blower ($10) which I bought for my 8800 because of these little slots in the plastic air tunnel which otherwise would dump a bunch of 70C air back in...
An other case modification to consider would be adding a 120mm (or bigger) to the top of your case... eliminating lingering air that may rise. BTW you barely hear the CPU coler's fan even when blowing at 100% because it is a 120mm, I can hardly hear my 200mm at all when I put my ear right up against it. And since you'd have to cut your own hole into the case then might as well go quiet for the top. But you mostly have to consider adding more intake... preferably from down low and where it would create a nice flow towards the exhausts while going over the needed components... HDD boxes usually take 120mm and two of them sounds about right , especially cause the HDDs would stay super-cool (and safer) and they'd slow down the air a tad.
The air-flow in it is bull-s!@#$... but if plugs and plays, and I get about 46MB/s our of a RAID1 which while not great it is 10MB/s higher than the POS Western... I wish you guys would clock yours with HDtach so we can compare the "Baby blue" to the "Puke Green"...
The Video Card is in and since I can't do 1080 1:1 CC previews till I get the LCD back I don't know if it does away with the choppiness but it does seem a tad better...
Oh! I also get my 3rd and 4th GB of RAM today, I had a promo code that brought it down to $105 from $125!!! And I am worried about the modules being changed on the HZs or it being discontinued... just want to make sure I have my 4GB that will OC the same... and I guess I might have paid $40 extra for it by getting it now instead of 4-5 months from now when Vegas 8 is out...
