paulcurtis
IMHO - FS can't stray far enough from 709 to make a inverse LUT usefull
If you really wanted to, you can try to build a inverse LUT by shooting a ChromaDuMonde chart, grade it to satifaction, and use a LUT builder program to build a LUT from the resualting grade... then look about for a LUT to ICC translation, i have never had a use for that, but it probbaly exists as the software we use for callibrating our mon's can create both... worse case is that you learn a bunch of cool things ;-)
d
Well the 709 describes a fixed gamma (which varies depending on who is documenting it!), which presumably matches the 709 gamma setting in the FS. There are other gamma settings though plus we can modify the shapes. So whilst not a log curve or anything the question is can we adjust the shape enough to warrant a different LUT? Perhaps not
As you say: for me, worst case is i get a better understanding of colour in profiles and pipelines from camera to film out, something that i've tended to just accept before.
EDIT: Frank, i'll look into the LUT Buddy, thanks
cheers
Paul
