guidedbygbv
I have a shoot on top of Mt. Washington -60 with windchill, How will this camera react? Any suggestions on rain covers or snow covers?
As a bit of perspective, broadcast cameras have long exceeded that 32-104 degree f spec. I had a 1995 betacam that I used in -15 f weather without a cover & without any problem .
The two largest issues you may face in cold climates is shortened battery life due to the cold and LCD refresh issues again due to cold.
Lastly, condensation can be an issue going from cold to warm . a simple way to defeat the condensation problem is to have an airtight barrier bag large enough to put the camera in when transitioning from cold to hot . Place the camera in the barrier bag and seal it up while outside in the cold. This puts the camera in an environment of low relative humidity. Carry the camera into the warm environment and let it come up to the warmer inside temp while closed in the bag. Once the camera has transitioned in temp , open the bag and you are ready to go.
Those are the same specs for the HVX200, and we used those in 57 degrees below zero with no issues at all (other than previously-mentioned LCD becoming an ice-crystal display and needing warming).The specs for the HPX300 are 32-104F.
