Conclusion
It is clear that current, high performance displays having higher brightness, higher dynamic
range, wider color gamut, and lower noise levels are beginning to show the weaknesses of
traditional display response functions, and that a new type of EOTF is required to allow these
displays to reach their full potential. It is also clear that this new EOTF must satisfy the criterion
of minimum visibility of steps using 10 or 12 bits, over a wide brightness range (wider than
available in current display devices in order to allow for future developments in display
technology). The conventional gamma based curve, which came from the no longer employed
Cathode Ray Tube (CRT), does not meet the requirements; experiments show that stepping is
visible at even 12-bits. An EOTF based on perception can easily meet the requirements. Even
over an extreme brightness range (up to 10,000 cd/m2), visible stepping is not apparent on test
patterns at 11 bits, or on images tested down to 9 or 10 bits.
They are talking about a PQ curve, the curve that is modeled after the Barten ramp, not a log curve.That's a good point regarding the graphs that makes it more clear, however, my comments on that graph were based on this conclusion from the same paper:
12-bit/Dolby Vision TV's have been out for about a year, though mostly on the higher end OLED models from LG and Sony.
Brightness is another key factor in HDR content. The Ultra HD Premium specification says HDR TVs must attain a minimum of 1,000 nits of peak brightness, which many of the current crop of HDR TVs can do. Nits is the measurement of brightness used for displays.
Dolby Vision content can be mastered for 10,000 nits peak brightness but at the moment, since no display can support this, content is actually mastered to around 4,000 nits. However, it's ready for when the displays support it.
Cameras currently do not encode using PQ, but of course, they could.
Personally, I do not think that would be the best solution, if I were the 'benevolent dictator' on video camera designs I would encode linear in 32-bit floating point, similar to EXR.![]()
So was black and white NTSC in the early '60s but we can thank those who decided to put things in color on film because now we have the technology to view it.Until then, per this debate, IMO 10-bit log is sufficient .....
So was black and white NTSC in the early '60s but we can thank those who decided to put things in color on film because now we have the technology to view it.![]()
Yes, but 10-bit Log is not the same as 10-bit PQ.Remember the debate was 10-bit log in cameras.
Marumi ND filters
Bull's eye!Jesus James, could you please stay on topic?
PQ is just about the optimum curve that uses integer values. Log is far better in that respect than linear but not as good as PQ. You simply cannot conclude that if it looks good with 10 or 11 bit in PQ then it is the same for Log. But 11-bit Log would get you pretty close.![]()
No, you are wrong, those curves are different not similar.PQ is fairly similar to Canon Log 2 (which is similar to ARRI LogC):
We all interact with mismatchers. Neuroscience can help us make those interactions more productive and positive.
Mismatchers are the folks who always take the opposite side of the discussion and will argue with anyone about anything. These are the folks who dis others, make snide comments, or belittle the work or beliefs of others. We see the behavior everywhere on social media, from the supposed gooroo whose cool angle is to diss everything he comes into contact with. Or the cantankerous negative commenter who is out to prove everyone else is wrong and they are oh so right.
If you are grading your video, take care to grade in Rec. 2020 with PQ or HLG. Using a different configuration, including DCI P3, will produce incorrect results.
The next time some mismatcher tells you how wrong, bad, out of touch or stupid you are- agree with them. Then sit back and listen for their next mismatch, and agree again. It won’t take long for the mismatching to stop and you’ll be able to move forward again.
... The anonymity of these platforms is akin to giving a 5 year old a loaded gun and then telling them, "Don't shoot yourself or anyone else." Chances are an uninteded shooting will follow. For me, I'm a mature, rational, intelligent adult but I die a thousand deaths when I see young kids and teens trying to navigate the treacherous waters of the Internet and social media when they are uninformed, impressionable, vulnerable to peer pressure and bullying, it's a poisonous combination and I fear that upcoming generations will have to deal with the psychological fallout of a few generations that have grown up with no faith, common sense and an absence of morality, their value systems primarily shaped by the dark depths of social media. As the snooty French maître d in "Ferris Bueller's Day Off" said, "I weep for the future."
But seriously, the pattern is that the elders fear for the youth. It happens every generation.
