Hello all,
I'm new to this forum and a friend pointed me in this direction after I recently took delivery of my new FS7 - I've been having a good read of other threads on here but I have a few questions that I'm struggling to find the answers to! I've come from a 5D MKII so jumping to an FS7 has been a pretty big step up.
I'm trying to get my head around using Cine EI mode so I hope these questions aren't too basic and that someone can spare the time to help. Any tips would be much appreciated!
1. Why is white balance fixed to three presets in Cine EI mode? If/when it ends up being slightly off while shooting (because it can't be dialed in), what's the best way to tweak it in post?
2. I know Catalyst Browse allows you to adjust colour temperature but transcoding hundreds of individual clips with tweaked white balances can consume quite a lot of time and extra space! Does anyone have any good tips for a Slog3 post production workflow in Adobe CC?
3. Is there a way of creating an assignable button that toggles LUTs on/off?
4. Do I need to expose Slog3 footage with a particular LUT in mind, or is there a safe way of exposing the footage so that a LUT can be decided on later? If I expose using the 709 LUT - is that the LUT that I have to use in post or am I flexible to use some other LUTs?
5. How can I determine the correct LUT exposure without being able to view a histogram or waveform without turning off the LUT? I can only view the histogram/waveform while viewing the Slog3 footage.
6. I understand that Slog3 footage should have a LUT applied before colour grading. If over-exposing Slog3 footage to achieve lower noise in post, should the exposure be corrected before or after applying the LUT?
7. Some of my clients will only perform some very light grading to footage that I give them. They've often worked with footage shot in Cinestyle from my 5D - does anyone know of a LUT that I can bake in to Slog3 footage or any particular Matrix settings to give a similar appearance to Cinestyle?
Thanks in advance - I've no doubt I'll be posting quite a lot on here in the coming weeks...!
