Haven't used that, but does that actually take any of the weight off? Looks like the pad is just pressed against your shoulder and the weight is still on your wrists.
Redrocks one looks more like a shoulder rig in that the shoulder pad is in a position that would put the weight of the rig on your shoulder instead of wrists. (may need to refresh page as picture rotates with a few other rigs)
Ye, I understand but then you cant use the camera lcd to view right?
Spiderbrace - It's plastic, but see here in use with adapter. Could work?
Yes. I did point out the spiderbrace is plastic, as I wasn't convinced it could take much weight. Thankyou for confirming my doubts.
Tim, does the Cavision support actually put any weight onto your shoulder?...or does it just rest against it?
I've got the Cavision dual handgrips which slide on the 15mm rods. They are very light- not the sturdiest things around, but work fine. I also wired them with a remote run switch because with the HVX/LEX in handheld mode it's impossible to hit the record button.
I'd recommend them. The price is certainly right.
If you're getting it strictly for adaptor work, because of the front load on an adaptor rig, don't bother with the shoulder brace. Just buy a cheap knee pad and some velcro - it'll work alot better.
