The HDMI port on the camera is for output, not input. I'm not sure why you'd want to use the 7D as a deck; if you're trying to view footage that you shot with it, then you can play that footage on camera from the memory card.What I'm asking is if these cables are so that 7d can be used as a deck for displaying footage.
Exactly. There's a button on the camera marked with a standard "play" icon (the little triangle) that will allow you to review your footage (and stills) right there on the camera. You can then use the HDMI port to connect an external monitor. The monitor will work when you're recording footage and when you're reviewing footage.
http://www.dvxuser.com/V6/showthread.php?t=182595&page=3what solution are people using to use a component or hd-sdi monitor?
