V vivsavage Member Aug 13, 2007 #1 I'm trying to copy the contents of a P2 card to a Mac-formatted external firewire drive. All options are available (Format HDD, Property, Setup), except "Copy to HDD". Any wisdom out there as to why this should be?
V vivsavage Member Aug 14, 2007 #3 No. it's Mac OS X extended. I formatted it in FAT32 and the computer hated me for it. Does this mean you can only copy to a FAT32 drive?
I Indywannabe Well-known member Aug 14, 2007 #4 It all depends on the devices and workflow you are using. You omitted all that.
B Barry_Green Moderator Aug 14, 2007 #5 You can't copy to the HDD unless you format it first. That's why "format" is there, but "copy" isn't. So make absolutely sure that the drive is empty, because when the camera formats it everything on it will disappear.
David Saraceno Moderator Staff member Aug 14, 2007 #6 The computer doesn't do it if you are copying from cam to HDD; the cam formats it.
