Barry_Green
Moderator
I think the reason nobody was answering is because the product wasn't out yet. I think Edius Broadcast has only just now been released, right?
OldManVideo said:Just got my Edius Broadcast upgrade 500 dollars. And, I believe it's worth it.
Tried several clips from my HVX200--720:24P--720:30PN--1080i. All worked on the time line in real time. You bring in the audio mxfs separately and you get all four tracks.
Will play with i further and see how work flow goes.
Cheers
Andreas said:And the info keeps coming. Great ! It will be intresting to hear from someone that uses Edius for capturing with HVX with a laptop.
icicle22 said:could someone who has Edius Broadcast report if the Canopus HQ codec shows as an installed codec for windows and can you import these files into Premiere or vegas?
stokestack said:Yes, let's hear the answer to that one. And, do the files retain have an "mxf" name extension? I don't see how software designed for AVIs is going to open MXF files, since it'll be looking for an AVI header that contains format info (like the codec ID). It seems that you'd need to put the DV50 material in a regular AVI wrapper.
Can the Canopus system ingest and export DV50 & DV100 material in AVI files?
smelni said:Just to clarify - to use Edius for DVCpro HD do you need the broadcast version?
What exactly is the difference between broadcast and normal
Have a look at the Canopus website: www.canopus.comAndreas said:Yes you need Edius Broadcast for DVCPRO-HD, and second question I dont know...
