Canon 7D, meet the Stouffer 4110C dynamic range test
Barry_Green
Moderator
After the Billups/ToNi shooting session, I decided I needed a better way to test for definitive dynamic range.
Enter the Stouffer 41-step transmission wedge, which is a calibrated strip designed to transmit light in calibrated 1/3-stop increments. Each step on the wedge is 1/3-stop denser than the step that came before it. So, every three steps = 1 stop. To calculate a camera's total dynamic range, you shoot the chart in front of a bright light source, and examine the steps to see where you can clearly distinguish between them, and wherever you can't, you take note of that step as the point where the dynamic range of the chart has now exceeded the camera's ability to resolve it. Whatever the number is, divide by three and that's the # of stops of dynamic range you're looking at (so, if it discerns 22 but not 23, you'd stop at 22, divide by 3, and end up with 7 1/3 stops of total dynamic range).
Much more repeatable than my prior test, and certainly less subjective in evaluation.
So -- I ran the 7D in every gamma mode, using contrast -2 to extend the dynamic range as far as possible. I also did one test with Highlight Tone Priority On vs. Off, and one test where I ran the same gamma curve through many of the ISO settings to see how dynamic range might change under higher ISOs.
In all these tests exposure was set so that the first step on the chart, step 1, the most translucent, was rendering on the waveform monitor as just barely darker than full clipped white.
So -- here are the results:
Draw your own conclusions. The way I see it, it looks like about 7 stops, maybe 7 1/3, in just about all the gamma curves. If you really dig into the shadows you might pull another 2/3 of a stop out, but I don't see how the most optimistic pixel peeper is going to be able to say the 7D is delivering more than 7 2/3 or maybe 8 stops.
Highlight Tone Priority certainly does some shadow-digging for you; without fishing around, the 160-iso strip stops at around step 21, and the HTP-enabled 160-iso strip stops at around 24. I don't know if it's actually added discernible dynamic range or if it's just pre-amplified the noise in the lower strips so that you can see them more discretely; you could probably extract the same range from the non-HTP strip in post. If you want maximum range without digging around in post though, maybe HTP is worth it. It definitely flattens the perceived contrast and boosts the brightness of the low-to-midtones.
As for the various ISOs, up to 1600 it doesn't really seem that there's any effect on dynamic range at all. They all get down to 21. But you definitely start losing at 3200 ISO, even though you can see strip 21, the noise has smeared the difference between 18 to 21 to a point where it's probably not "usable" dynamic range. At 6400 ISO the noise is contaminating all the way up to step 15, mushing to a blob of noise between 15 and 21 to the point where it's probably not usable.
So, there you go. I put it at about 7 1/3 stops usable range, and depending on how low the ISO is, you could probably post-boost it to 8.
Thanks Barry.
It was my understanding that using the "non-native" ISOs (320,640,etc.) produced less noise but also less dynamic range than the native ISOs (200,400,etc.), and my testing seems to confirm that.
Personally, if I use HTP, I will use a non-native ISO to counter some of the added noise, and if HTP is off then I'll stick with native ISOs.
Oh, no you di-uhn't!...
Thanks for your tests, Barry. I appreciate all your insight and efforts.
Basically, I bought the 7D for both it's stills and video capabilities. For what it CAN do, I believe it to be a bargain.
Thanks Barry.
Wait, explain this if you haven't vanished already. LoL
Non-Native ISOs producing greater/extended dynamic range sounds off to me. Do you have any tests up? And how do non-native ISOs (adding more noise and odd cross hatched patterns to the image) combat more noise added by Highlight Tone Priority? I'm not saying you're wrong, I just haven't heard this one yet and looking for some insight.
Also, I am STILL hyper-curious to see if higher ISOs, native or non, retain more highlight detail than not. I guess it's time to go out to the Skate Park and run this theory.
In the end, I want to see how much can be pulled from shadows with the cleanest settings and from the highs in the same scenario.
Now this is more like it.
Have you done this test on the 5D as well? Particularly interesting to see the ISO levels and how noise affects darker areas of the image. Would love to see how 7D and 5D compare at ISO 3200 and ISO 6400 on that chart. Dynamic range test between the two would valuable - but isn't dynamic range about colour as well, not just gradients from black to white? What if one colour channel has more dynamic range than another?
Also what screen and what software are you using to compare and compile the samples? Could gamma levels affect one's perception of the chart? 5D / 7D footage looks really dark on my Macbook until I transcode it. Were these samples taken directly from the H.264 footage?
Vanished?
Here's a post demonstrating what I'm talking about: http://forums.canonphotogroup.com/showthread.php?t=2541
It was a test done for the 5D, but seems to apply to the 7D as well based on my observations.
In short, native ISOs are 100, 200, 400, etc. Non-native ISOs 1/3rd of a stop directly above a native ISO (125, 250, etc) have higher noise, but non-native ISOs 1/3rd of a stop directly BELOW a native ISO (160, 320, etc) REDUCE noise at the cost of some dynamic range. This seems to hold true until about ISO 1600.
So, my reasoning is that if HTP adds what seems to be 1 ISO stop's worth of noise AND dynamic range, using a non-native ISO 1/3rd of a stop below a native ISO brings some of that noise back down (seemingly 1/3rd of a stop's worth) to an acceptable level, while keeping most of the benefit of the HTP. Basically, it's kind of an in-between step between HTP completely on or off.
Vanished?
LoL! Sometims when people ask questions, the original poster vamooses and we never get them answered. That's what I meant.
You're saying the native ISo's are 100, 200 and 400. That's much different than what everyone else is reporting: 160, 320, 640 which are much cleaner than anything else.
I'm confused now myself, because I certainly see 160 as noticably cleaner than 100.
Dynamic range is about brightness, not color; that's why a wedge chart like the Stouffer is gray ND.
I don't use a screen to compare, I use a waveform monitor. And yes, if you're trying to evaluate something using a computer monitor whose gamma is off, you're pretty much at the mercy of whatever that display will show you.
And yes, I only ever work off the native h.264 footage.
Yea, it seems the native ISO's have a bit more dynamic range since the others are achieved by messing with them. Daniel explained all of that to me over at Reduser and he really knows his technical stuff. I've been shooting nothing but natives unless there is no way to get correct exposure at night but use one of the others.
It seems part of the reason why some have less noise is because they get the blacks crushed or cut completely... I can't remember the explanation, I have been meaning to make myself a cheat sheet though. Let me find that post.
I have read arguments on both sides, but feel the article I linked to makes the most convincing argument that the native ISOs are indeed 100, 200, etc. and that 160,320, etc have less noise because they are being "darkened" digitally. Of course, if anyone has a better interpretation of what might be going on, I'd love to hear it!
I don't know that anyone outside of Canon Japan knows what the "true" native ISO of the chip is. The idea that there could be multiple "native" ISOs is just bizarre to me. I've never heard of that before.
Traditionally you have a chip with a base native sensitivity, tuned to deliver the maximum dynamic range and sensitivity and least noise, and that's where it's set at. Then you gain up (or gain down). Gaining up will add noise and take away dynamic range off the top. Gaining down will clean up noise and take away dynamic range off the bottom. At least, that's how it works in any video camera I've ever tested.
So ... multiple "native" ISOs? Weird. And to have basically the same dynamic range across multiple stops? That's different too. Obviously the stills guys do it differently.
So whether they're "native" ISOs or not, there's no arguing that the 160/320/640 ISO grouping is cleaner in noise than the 100/200/400 groupings.
There is indeed no denying that 160/320/640 are cleaner, but if that's at the cost of dynamic range, which it seems to me to be, then that is worth looking into.
And regarding the whole native ISO question, perhaps there are steps which are done at a lower level (100, 200, 400) and others which are done at a higher, or later, level in the camera to add the extra steps (125,160,320, etc). Hardware vs. software? Just a thought..
Here, start with the last post on this page and read his posts in the next page or two: http://www.reduser.net/forum/showthread.php?t=34434&page=25
It seems there are only a few analogs and the rest are processed digitally.
There will be "multipe native ISOs" since noise is becoming so low through a range of sensitivities that you can get a rich and clean image on a range. However the tern "native" might not work for that. Native shoud be the absolute best, one. But a new term should be brought on for a range of ISOs that give you an image that is hard/"impossible" to argue with.
Thanks for that. The first post on this page seems to explain it best:
http://www.reduser.net/forum/showthread.php?t=34434&page=27
100, 200, 400, 800, 1600: normal amount of highlight headroom.
There is little difference from ISO 100 to 200, because most viewers can't tell the difference in photon shot noise, and the read noise drops by almost a full stop in ISO 200.
125, 250, 500, 1000: considered harmful. 1/3 stop less highlight headroom and 1/3 stop more shadow noise.
160, 320, 640, 1250: fine, as long as you are aware of the decreased highlight headroom. (Clips 1/3 highlights to get 1/3 more shadows.)
HTP should *always* be enabled when the ISO is higher than 1600.
There is a careful balance between increasing shadow detail through ISO (which clips highlights) or through HTP, the picture profile (e.g. contrast, tone curve), or Auto Lighting Optimizer. Generally, the higher you go in ISO, the more beneficial it is to use non-ISO methods to increase shadow detail. For example, ISO 3200+HTP (actually ISO 1600) is better than the real ISO 3200. ISO 800+HTP may be better than the real ISO 800, but it depends on how much highlight headroom you need.
No problem Kholi. Thank Daniel over at Reduser, he keeps pouring detailed knowledge all over the forum.
I keep trying to remember the numbers. The easiest way for me is like this.
100 = best
125 = hell no
160 = 1/3 stop less highlight
Then 1600+ always use HTP.
I should write that on my hand.
Quick question, does this test take into account that quicktime color space issue that clips blacks much sooner? Or does that not make any difference?
