Remember that this is an EF-S lens and can not be used with a full frame sensor camera later. That is a major turnoff to me, so I bought the EF 17-40 F4L instead (around $700). Seems like this lens will hold it's value much better.
I bought the 15-85 with my 7D back in october. I recently sold it in favor of primes. The wide end had too much distortion and looked awful. The long end was way to slow for any low-light/indoor use. I now have a 24mm 2.8, 50mm 1.8 II, and will be getting an 85 or 100mm very soon.
Another good idea would be to look at the tamron 17-50mm 2.8, then get an 85mm f1.8. Throw in a 50mm 1.8 II for good measure. This would be a pretty good setup.
http://www.photozone.de/canon-eos/462-canon_18135_3556is?start=1
here is a less than stellar review of that lens and is especially bad on the wide end and opened up all the way (which is where you need it). On an aps-c sensor, you really just need the wide end of the standard lens set. I went with a quality wide zoom (17-40 F4L and I would have got the 16-35 F2.8L if I had the money)), a 35mm f2 and a 50mm f2. I may add an 85mm later, but it has not been needed so far as th 50 is plenty long enough for me right now.
Buy the right thing the first time, even if you get the kit lens for a deal it is money that you could put twoards a lens you will use. The only exception I would say is if you plan on selling the 7d soon (say 6 months) and will need a lens to sell it with.
Yes, but that is an ef-s lens and pretty pricy. If you have those primes, you could just get the 5Dii and you would have plenty on the wide end, since getting something nice enough for what you want is going to probably cost you the difference between the two bodies.
