Ryan Farnes
Can a firmware update potentially fix moire and aliasing? Or at least lessen it?
I heard when he mentioned this also. It makes sense. I think he said something about it using a certain part of the sensor to accomplish this. That’s cool to know because then there should be something in the firmware telling it to read every line. If he could find and manipulate that code then it should be possible for it to be hacked to read the whole sensor in video mode. It might end up causing other issues if it could be done…but up until he mentioned it I didn’t think that it would be a possibility (still might not be…but Trammel will find out)... just Like Trammel said When you do Digital zoom and the Morie is gone BC the camera does not Skip Lines…
Right, it's called "windowing". Red does the same thing to get their 2K. Reading a smaller portion of the sensor is one way to let you read it at a faster frame rate.I heard when he mentioned this also. It makes sense. I think he said something about it using a certain part of the sensor to accomplish this.
Nope. Not the whole sensor. The silicon can only be read at about 8fps or so, nothing Tramm can do about that. The solutions are to only read a little bit of it (either windowing, or skipping a whole bunch of lines).If he could find and manipulate that code then it should be possible for it to be hacked to read the whole sensor in video mode.
You know...that's not a bad idea right there. That would at least leave us with a choice on what mode to shoot at for a given scene. Everything wide would be shot in this mode while closeups (or anything to do with shallow DOF) shot in "normal" mode. He did however mention increased noise when doing this...which is typical with any kind of digital zoom.He could maybe make it read in "digital zoom" mode, reading out that window, moire-free -- but if doing so, you'll end up with a little window and the field of view more like a 1/3" or 1/2" video camera. Say bye-bye to your shallow-DOF look.
Of course, that might be just fine anyway -- the moire is at its absolute nightmare worst on wide-angle shots, and do you really need shallow-DOF on a landscape? So it might be a good reasonable compromise anyway.
