cpreston
I did a bunch more tests trying to match my XC-15 and C100 II to the c300 II. A couple of conclusions:
- the Kelvin scale matches about 200 to 400 less on the C300 II when white balancing. 3200 on the c100 II matches to 3000 on the C300 II. If you try to manually match the cameras using the same Kelvin setting, you will end up with the C300 II looking more red
- the C100 II emphasizes green in the skin tones relative to the C300 II in neutral settings. In the production camera setting on the C300, greens are much more emphasized and blues are diminished.
- in all settings, the C300 II tends to add reds to the blue at a higher proportion than the C100 II. Neutral is the closest setting for maintaining blues. If you want more blue to violet, you can add a couple to the phase or change the b-r and/or r-b setting in the profile. It's really a very slight difference, but the effect on the appearance of those saturated LED lights is significant.
Implicted may have a broken sensor, but for those people unhappy with the blues straight out of the camera, I would suggest using the neutral profile and then changing the r-b setting.
