Hi all
Could someone explain the difference in use using the C200 vs 1d Mark II which I use now. I only shoot wildlife and with long glass, 200-400mm, 600mm, 800mm etc. So no run and gun here, usually all tripod mounted. I normally only shoot 4k with the occasional 120fps. I have a fair amount of CFast cards so that is no issue with either setup. I do not do this to make money but for self use. I always wanted to jump into the Cinema line but never have. I was thinking the C200 may be a good move but maybe not enough for what I already have and use. I do take the occasional screen grab for the footage too. Not sure is the C200 even does this. Any input would be great. I am very happy with the 1dx Mark II but was wondering if I am truely missing something vs the Cinema line. Looking forward to your input.
I do use screen grabs like this also
Goldfinch by A & R Photography, on Flickr
I do use the SmallHD 702 monitor with the zoom h5 at times but I also use just the camera at times for easier and faster setup depending on location.
Here is a setup with my 800mm, I have since upgraded to the Sacthler FSB8 which handles the payload much better. I do not always mount the Mic there and move it off camera so I do not get the AF noise when using DPAF.
Canon 1D X Mark II video setup by A & R Photography, on Flickr
Here is a setup using my 200-400mm with the monitor off to the side.
Out in the field by A & R Photography, on Flickr
I like doing clips like this
Goldfinch by A & R Photography, on FlickrI do use the SmallHD 702 monitor with the zoom h5 at times but I also use just the camera at times for easier and faster setup depending on location.
Canon 1D X Mark II video setup by A & R Photography, on FlickrHere is a setup using my 200-400mm with the monitor off to the side.
Out in the field by A & R Photography, on FlickrI like doing clips like this
