GaryinCalifornia
Its been so long since I thought about this... I wonder if someone will make a plug-in to de-interlace the footage so you can do slow-mo...
I was wondering if any C300 owners have converted the 1920x1080: 59.94i to 24p yet and if so could post an example...
I've not done this, but I am curious how it would compare to the 720p60 footage. I'll try to do a brief comparison over the next couple of days and post results.
My prediction is that the results would depend on the codec used. On the C300, you might actually get slightly better results from deinterlacing 1080i60->60p for slow motion than with upscaling 720p60 to 1080p. Even assuming the worst case for loss of vertical resolution (that being an effective drop to 540) there is still much more horizontal resolution in the 1080i image than in 720p.
However, using the internal avchd codec on the C100 would be slightly different. The C300 records 4:2:2 internally, but the C100 is only 4:2:0. Luma resolution would be the same, but chroma resolution is devastated when 4:2:0 is applied to interlaced footage. On a hypothetical C100 with 720p60, you'd probably be better off recording 720p and upscaling as 4:2:0 handles progressive chroma better than interlaced.
For the C100, this is probably one of those scenarios where an external recorder with 4:2:2 would be of use, even if it doesn't do 1080p60.
But of course, that's all theoretical.
I can do the test with the 35Mbps 4:2:0 codec setting to approximate a more even playing field with the C100. Theoretically, of course.
Cowpunk52 shot some footage for our team at 4:2:0 35MBS with his C300. Our editor loved the footage, and she is a television network editor so she deals with broadcast footage. His 4:2:0 35mbs footage was much better than our FS100 footage. From this shoot we released a short event video where the speaker had to be cropped from about one quarter of the frame and even though it was filmed at what I think was 6400 ISO, not sure, the result was acceptable even after color correction.
I really look forward to Cowpucnk52's test. He is the man when it comes to optimizing the C300 and I eagerly anticipate what he can do with the C100. Canon get him a camera,
One thing I thought of was, do you think that because you used a pretty shallow DOF, that maybe it covered up some of the artifacts that might normally show with a process like that?
Did you try it with out such a shallow DOF? And if so, were the artifacts more noticeable?
