Brand new with dirty heads!
livy500
Hi,
I just got my HV20 brand new, used it once and then next time I turned it on said that it needed it's head cleaned (Note: I use Panasonic AMQ tapes only). I've read other posts here saying Canon ships some HV20s with dirty heads.
24Peter recommends running a tape head cleaner thru for 10 seconds. This makes me nervous b/c I tried this with my two older cameras, one a Sony, the other a Canon, and it went from occasional audio dropouts to producing video glitches every 5 minutes or so.
Have people had problems with running tape head cleaners with the HV20? Should I use different tapes? Any advice? Should I return it just in case?
Thanks,
livy500
The heads/drums on band-new tape decks (including those in cameras) sometimes can scrape off a little more oxide from the tape than they do once they are "broken in".
Running a cleaning tape should fix the issue.
- Mikko
are there any prevention steps to ensure that there won't be any dropouts? besides
or is there any method to confirm that the upcoming shoot will have no problem with the head?
how many hours do we need to run the cleaning tape?
The cleanign tape should run for only about 10 seconds at a time. Then check the deck. If it doesn't clean, try again up to 2 more times (3 times total). If that doesn't clean it, then you'll need a more robust cleaning.
After just an hour or so, the heads on most decks will be "profiled" to the tape and shouldn't produce any problems.
- Mikko
