AndreeOnline
Blackmagic is 16-Bit Linear, stored at 12-bit, unpacked back to 16 in Resolve.
one good test is exposing a high contrast scene -2, -1, 0, +1, +2 stops then adjusting in post to same base level exposure level.
no, bmc doesnt work that way. BMC works by maximizing the information the data it gets per shot. it will always be corrected in post. ALWAYS.
Canon is the old hand in the skin game.
definitely reasonable, I'm gonna need some assistance for the BMC though, where is middle grey supposed to be for the correct allocation of dynamic range, I know how to set it on the other cameras,
Wow I went to sleep after my post and woke up to all this .... :huh:
For the latitude test I suggested (if you're still interested in doing it) your best bet is to stick a grey card in the scene and measure 50%IRE on it with each camera. The C100 and BMC don't have a waveform monitor built in or even a spot meter so I would strongly suggest to see if you can get an external monitor that has one built in for this test. It would really help make everything more equal.. ie. using zebra stripes on a grey card can be subjective and may not be as accurate. Be careful on the Scarlet if planning to use an external monitor as what you see or read with it can actually be deceiving because RED allows you to adjust the image output without adjusting what you record! (Double check under the LOOK menu that things are reset). I've seen people get burned exposing using an external monitor not realizing someone else before them has altered the settings. On the Scarlet your best bet is to just use the FALSE COLOR feature and read GREEN on your grey card.
To really test the latitude I suggest setting up the camera indoors in a dark room or if outside under a large overpass or bridge, then also include an area of your image directly under the sun in your shot as well. It could be buildings in the background if you're under a bridge, or it could be a view out a large window if you're inside. Mix a bit of both dark and bright in the shot and just worry about securing that grey card once you found a spot that will give you 50%IRE on it. :happy:
I feel the aperture setting on the lens is really important too for conclusive testing. Most people would stop up and down using the lens for such a test but that alters the depth of field and also changes the characteristics of the glass. Me, I would pick f4 to f5.6 and use 2 stops ND filters as the "baseline" and then add/remove additional ND filters to get -2, -1, 0, +1, +2 stops. Indoors you might need additional lighting to get your grey card to 50%IRE and be sure to throw some light splash on a nearby wall and get some gradients going.
RZE - still up to the test?
I believe we are entering an age of cameras where detail no longer matters - they all gather lots of detail, the new frontier is skin (and color science). Red is a perfect example, look at how much their color science has improved over the years. Canon is the old hand in the skin game.
really? Nikon has always had nicer skin tones in photography (imho),
...and the BMC seems to have nice colour science in moving image (imho)
Just to clarify - the C100 does have a built in WFM.
Back to the thread
nikon was not mentioned in this test, nor have they entered the large sensor camcorder arena
I have yet to see bmc skin tones that I like and believe me I've been searching (because I wanted to believe in the newcomer, the underdog). I gave up, so somebody post something with decent skin please. Back when it was just John Brawley posting tests the only thing I saw that came close to decent was the girl playing pool. Everything else I've seen the skin looked plastic
Nope.With digits?
With digits?
I've seen side by side private Alexa and Blackmagic tests, they match out of the gate.
in order alexa, canon , sonyDo you like F35 skin or Alexa?
