That's the maximum -i.e, burst - bit rate. The max rate depends on the buffer within the card. Once it fills up, the bit rate will slow down, often drastically. The constant recording rate is not known or published.Transcend has a 180 MB/s write rated card that BMD suggests for this monitor for recording 4k. That should be plenty of speed...
This is why the SD group came out with the video recording standards that specify precisely that, the minimum sustainable recording bit rate as indicated by the ratings on the card. There are several classes, as from the link I provided. It starts at 6 (a V6 category) and ends with 90 (V90), all in minimum rates expressed in Bytes per second. Presuming no manufacturer wants to be accused of an outright fraud, a compliance with these standards will ensure a consumer that any card s/he decides to purchase will perform exactly as stated. The current labeling of the max bit rate recording does not accomplish that.
And, again, I bring this up because ProRes 4:2:2 HQ is 880 Mbps/110 MB/s, which exceeds the maximum sustainable bit rate of the latest generation of SD cards (in fact, I haven't seen the V30/60/90 class cards yet even advertised). So, if VA4K advertises itself as ProRes 4:2:2 HQ capable, it's - to use the most generous of interpretations - only applying the max/burst rate without any indication of how long this burst rate can last.
This criteria also apply to the card manufacturers. The burst rating was fairly suitable for photographers but nigh useless for videographers. Which is why the SD card manufacturers went Sue Grafton and created a V-rating, where V stands for Video.
