There is an 8mm lens if you really need one!
http://www.sigmaphoto.com/shop/8-16mm-f45-56-dc-hsm-sigma
Canon has one 8-15 f4 very sharp and Rokinon 8mm . That would give us 18 mm fov and the distortion ...well the wides in Inception where very distorted IMO but then Im going off topic.
Will a fish eye distort less at this crop? Enough less?
Yes. The high dr makes it look really Filmic. Not dof. Not sensor size.
My only qualms with the cam is i dont have lenses that are wide enough for it. But i do hope 11 is plenty enough
The rokinon 14 looks like a great and balanced deal. Me thinks that's my wide.
Why not the Tokina?
Why not the Tokina?
I sure do wish the same was true of Thunderbolt.
In terms of zoom you have the olympus 14-35 f2.0 for m43 and the soon to come panasonic 12-35 f.28. They have thre coresponding 35-100 also. A 24mm would equal more than a 50 mm on photo 135ff, so I don't think anyone would consider it as a wide. Perhaps you are use shooting only talking heads or exterior, if else you would see why people woud need wider lense. I an not talking about ultrawide but at least a 24 mm (again I am talking photo size). So the only solution would be for now the 11-16 Tokina, which is a good lens, but I think thats it. Now in M43 you have the 12mm olympus at f2 (that you mentioned) but also the slr magic 12 f1.6. You also have the 17 and 25mm f.09 voiglander lens, and many other comming out that are design to mimic standart lens focal range with fast apertures. The longer end is ok because ith the flange distance you can adapt more or less everything.
This is why I see your post a bit bizar. Because for this sensor size the m43 lenses are much more adapted. The olympus f.2 and the voighlander would make this camera much more closer to the look (dof) of the larger sensor camera. I really hope they put it on the priority list even before PL mount. Because the market they are aiming at does not have that much money for cine lens and if need be someone can put a pl adapter to a M43 mount.
And 14 is what I need to get to gh2's 17mm, which is the widest I ever need or want to go on that camera. Works for me.
