longshanks
I've been mulling over this for months...literally pouring over forums trying to find the right set-up for my needs.
I own the T2i and with all my rigging set, its just shy over 10lbs. I'm thinking I need a tripod kit with a max weight limit of 15-20lbs as I'd like to be under. I know Philip Bloom likes his Miller Solo, but I've looked at the sticks on it and I think I would absolutely hate to use twist grips in order to adjust the legs. Preferably, I like the old turn knobs similar to the Libec LS-38 and higher end Sachtler sticks. Although it seems that Manfrotto and Sachtler are doing a lot of lever releases for their legs.
Leg adjustments aside, I'm wondering if I really need to keep in mind weight when moving around a lot. I consider that most event shooting should be slimmed down and as simple as possible. In this case, it would be best to get a lighter weight tripod with no spreader(or spreader removed) for moving quickly to different vantage points. However, when shooting music videos, short narrative, and even some documentary work, I can see myself using a heavier duty tripod with a mid or ground level spreader, especially with the camera rigged-out.
So far I've been looking at getting the Sachtler FSB-6 kit from B&H(my favorite so far), Cartoni F101, and for the lower end, the Libec LS-38 or Manfrotto 503HDV(least favorite).
I've used both the Manfrotto and Libec and I'm somewhat unimpressed. However, I feel that the Sachtler might be over kill for the T2i especially when its not rigged up with extra weight. But then again, it only has a 13lb pound capacity.
Hopefully this thread won't fall into the downward spiral of personal preference(Sachtler v. Cartoni i.e. Ford v. Chevy) as I'm really just trying to nail down the right tripod for my needs.
