Julie_Freed
Any recommendations?
I've read about the Glidecam HD-1000 and the Flycam Nano. Can anyone vouch for those or any others? Are they hard to use if you plan to change lenses frequently?
Extremely, every time you change a lens you will need to re-balance the whole set upAre they hard to use if you plan to change lenses frequently?
Roman, can you focus while using the Glidecam?
@maran... I understand your point cause in order for it to work, you have to be in great CG... but that being said, I've flown a lot of rigs over the past 2 years and the heavier the rig.. the better hands down. It resists the physics of movement and stays in one place and will fly the rig, because a good flying shot.. the operator is just guiding but very lightly... so the rig is just doing the work.. So when you see pro steadicam rigs, they are always beasts and rightly so... You have much less variance when you have more weight, than you do with less weight...
