You know, the 7D does include an LP-E6 battery and charger. I think that the charging time is like two or three hours though. You can get an hour to an hour and a half on one charge. But you should be using Live View as sparingly as possible.Thanks! I think I am going to stick to the LP-E6's for the information which I find necessary. But thanks for such a detailed post.
I found that the charger is the LC-E6, and B&H has both the charger and the batteries for the best price and with no shipping or tax. Unfortunately the charger is out of stock. I think I am going to start off with three batteries and two chargers since I need it to be dependable and will use it in the freezing cold.
LC-E6 Charger - $60.-
LP-E6 Battery - $70.-
Do you know how long it takes for the LP-E6 to charge from fully drained?
well since I will be using the Zacuto Z-Finder and that means live view all of the time, looks like I will be investing in a battery grip
how long will the battery last while shooting 1080/24
You know, you can use the optical viewfinder while you're setting up the shot. Then use live view to check the exposure and maybe focus before recording. I just don't see why you need to have live view on almost all of the time. The exposure settings and camera configuration are independent of live view. Turning off live view does not entail turning off the camera. Without live view, the camera consumes very little power. On the 5D Mark II, the settings don't change when you power-cycle the camera. I don't expect the 7D to behave any differently.
Why would you assume that the settings would change?
Well, the camera doesn't have an EVF (electronic viewfinder). It has a plain old optical viewfinder. So while you can use it to set framing and preliminary focus, you won't get a WYSIWYG exposure preview or focus assist.
Not really. You can determine roughly where you're going to put your lights and where to point them without using live view. You can also use an old-fashioned, hand-held light meter to find your exposure without live view; that way, you don't even have to use live view until just before you record.Yes, the lighting will require the live view and that's what takes the longest.
It is. Why wouldn't it be? The image that you see through the viewfinder is straight through the lens, and DOF is a property of the lens. The whole point of an SLR is to allow a photographer to see the exact image that will be recorded by the film or sensor (exposure excluded).Though for that you sort of also need DoF to be accurate on the OVF. Is it accurate?
