Baby F3 aka NXCAM S35
what do you mean "in highlights"? It has been scientifically tested to have a solid 12 stops of DR, which is around 2 to 3 more than the 7d, and any other dslr, in video mode. I don't know how much more cut and dry you can get than that.....
perhaps you are referring to the cute gradual shift in hue and softness once a dslr's video processing gets near the top 10% of the IRE range, but I prefer my capture device to leave that neutral and let me do it in post if I desire....
http://provideocoalition.com/index.php/freshdv/story/f3_vs_af100_vs_5d/
best is to hire F3 for half a day.
My friend bought one so i could do my own observations.
Yes, that helped me see the massive four stops of DR the f3 has over the 5d/7d quite clearly. ignore the std gamma test, that is meant to model a rec.709 color space, and has awful highlight rolloff. Pay attention to the cine4 curve (which is still not ideal, cine1 contains the most even distrobution of information in a 0-110IRE space, and the nicest rolloff. This is why I never take these tests with more than a grain of salt, the cameras are rarely calibrated, black balanced, and set up properly for the shooting scenario). It's pretty easy to tell how much more information the f3 is capturing by looking at the shadow of the image. Where the 5d is completely crushing to black, the f3 holds plenty of detail. Because of this you can stop down, and regain plenty of highlights. But even if not, it's holding more details in the specular of the apple. This is all pretty apparent by just glancing at your own link, I'm not sure why we're discussing this. Back to CML I go.
(and by the way, I have shot with a 7d, and a d7000, on more than one paid shoot. The contrasty, sharpened image looks great out of context, but when you get it into an editor next to footage from something like an ex1, it's complete lack of shadow and highlight information becomes pretty apparent. Not to mention the grading hassles that pop up. You do what you can to recover the information, but things like secondaries are near impossible due to the compression)
No problems with grading here.
All our work goes to CINEFORM.
You can also set up your Canons to way you like it.
So which F3 did you buy?
It is a bit presumptuous to make any judgement from some youtube videos. The concept that if you can already see the difference from a low quality output like youtube, so that the difference will be much more visible with a higher quality output, is good if is the same person doing it in the same conditions. There are so many variables like how it was encoded, the lighting, etc, etc... that any conclusion is just impossible. Until someone does some side by side or chart test we will have to wait. This does not mean that the FS100 and F3 have the same image quality because they share the same sensor. Since the day we knew that there was no 10bit output I have been worried that this is not the case.
About dynamic range, I don't understand why people always talk about highlight handling and not total dynamic range. It is the relation between highlight and shadows that gives you true dynamic range. Coming from still photography and having worked with lot of sensor you can see that they have different response. Sometime some sensors (camera) are more bias toward highlights and others toward shadows. So sometime you can regain a lot of detail from the highlight that seemed to have been blown or dig a lot into shadows that seemed crushed. You have to expose accordingly. For the case of a sensor which is supposed to have less highlight handling, you just underexpose a bit so that the highlight are not blown and then boost the gama of the image in post. I don't know what is complicated that much and give me the 12(near 13 stops) of the F3 any-day against any 10 stop camera which might seem at first sight to have better highlights. I think the more people in the video world will have proper quality image capture that can rival what still photographers have been enjoying for so many years the skill set and mentality will change. People will be more used to what I call 'shoot to edit'. In the video world the images for the great majority has been so low (comparing rez and dynamic range) that people have been use to try to get everything more or less right in camera and making a lot of compromise in the middle.
Hmm the 5d is not crushing blacks at all. You can see a black shadow on the 5d image but that shadow is also on the f3 but just slightly more to the left. Take a look at the banana. I always thought the 5d had a pretty good DR, I've had absolutely no problems with the dynamic range on it. Compared to some prosumer cameras like the Sony V1 or Z7 cameras, the 5d is visible better than those on DR.
Apparently you guys did not set the image settings properly. Contrast to minimum on NEUTRAL settings?
Daniel, the video we were watching at the EC event was directly out of the cameras. 8bit 4:2:0 video using the kit lens. It looked very much like what people are seeing on Vimeo, but at higher rez. BTW, no aliasing on either camera. No moire, either.
I say again. I'm convinced we have yet to see what the FS-100 is truly capable of.
One thing that hasn't been discussed is the built in GPS. If I understood what was said, each camera can have it's clock set to exact date and time. No need for jam sync.
Apparently you ignored the last statement I made. I'm not judging the camera in it's current configuration. But rant away if it helps you. What I did see at the exihibition were cameras that were setup by people who new what they were dong and had time to dial them in. I guess you didn't read that part either. I was observing this on a 3K Sony OLED monitor too. In low light, the camera is excellent, but the highlights were less than ideal. If you want to 'believe' this camera has what you need before it's actual release, then go ahead. I observed the cameras in real time with top of the line equipment.
My statement about fast glass and an ND filter were obviously speculation. Something you conveniently ignored.
I'm sure with time and experience somone can dial either of these cameras in to look good. But I stand by my statement that the FS-100 in it's current config is unable to take full advantage of the new sensor. If that doesn't matter to you, then fine. The new sensor is capable of better than 10bit color and excellent dynamic range. The FS-100 lacks the circuitry to take advantage of that. I also fully expcect Sony to use feedback from the field to finetune the Cameras abilities. How many times do I need to say that before you get it?
I still don't understand why fast glass an and ND filter makes any difference from this camera to any other camera? I've used fast glass on both my 7D and AF100 and it was for DoF consideration. In fact, given the low light performance of the FS100, I'd say people are going to be able to use slower glass and get more usable images out of it at higher gains then a lot of other cameras.
I'm not saying the FS100 is perfect, just your speculations made no sense to me.
And I too looked at Jan's AF100 attached to a professional Panasonic monitor playing back footage taken on the Prototype AF100 at a trade show, and I saw the same noise issues we all saw long ago, yet, on the final production camera, I've never seen that problem again EVER in my footage.
No one knows anything about the specific details of the sensor in the FS100. I still stand by my original assertion that while it's the same sensor as the F3, the performance of CMOS technology is not a fixed specification. There are variations in the design process that are unavoidable and most companies will performance bin their parts. If I were sony, I'd take the top performers and put them in the F3 where their usage will be fully realized, and take those that maybe aren't as high performers and use them in the FS100 where the difference in operating range on the output (8-bit) is more than sufficient to utilize the performance. Less waste. This practice has been going on for years, Intel being one of the most popular for doing it.
I still don't understand why fast glass an and ND filter makes any difference from this camera to any other camera? I've used fast glass on both my 7D and AF100 and it was for DoF consideration. In fact, given the low light performance of the FS100, I'd say people are going to be able to use slower glass and get more usable images out of it at higher gains then a lot of other cameras. ...
Fast glass is almost always better quality than slow glass. And ND filters allow for more control of exposure to keep the image from getting blown-out; stopping down past about 5.6 adds diffraction distortion to the image.
But I have a sneeking suspicion that you know all this already, Rick.
An nd will affect all the image exposure and is not related to blown out at all (in the pure sense I mean). Someone just need to stop down the lens or have a higher shutter speed, but these will affect the esthetic of the image. That is why putting some ND to reduce the light reaching the sensor will help so that you can have shallow depth of field and a shutter speed of 1/50 for film motion blur. The 3.3 megapixel aps sensor of the fs100 will mitigate a lot the diffraction distortion because the pixel are so huge. You will have to stop down a lot to really feel the effect.
I guess we will have to wait a little more, because it could be a pre-production camera that has not been tweaked completely. I don't subscribe to much to the binning theory of the chip. I think that any difference will come much more from the hardware component used. For my needs I hope that the dynamic range will not suffer. If it does then I will stick with the Gh2 (with clean hdmi), because it will be silly to say that it has the F3 sensor if it is crippled that much. Perhaps a hack could give us region free version and 10 bit, it would be perfect then.
Maybe a firmware upgrade from Sony would do the trick. The only thing this camera has in common with the F3 is the sensor. There is no 'binning' going on. I don't know where that came from. But the internal components are different. Not a complaint, just an observation.
I like this camera very much, just trying to keep a realistic attitude about it. People should not mistake this as an affordable F3. It is better than an AF100 though. Once 3rd party external recorders are able to record/store the 8bit 4:4:4 option, I think many of the problems we are seeing will disappear. But we won't know for sure until it ships. Juan Martiniez said Sony is working with 3rd party recording companies. I'll take that at face value.
Hehe, yes :) My point being that most of the lenses people are using are for stills, which in many cases out resolves the sensor used for HD by quite a bit, are far from being the limitin factor. In selecting lenses for say the AF100 or the FS100, or even the F3, I don't see how faster glass or ND filtering is really any different a concern, other than the F3 and AF100 have ND built in. Granted, I think the F3 and FS100 perform better at low light from initial tests I have seen, so faster glass on the AF100 could be determined as more important in the future comparing the cameras, nothing about what I see from footage shows the FS100 needs faster glass than say the F3. Looking at the 30dB samples are REALLY nice. Given how sensitive the camera appears, and the fact the pixels are larger which really helps the diffusion issue, both cameras will require the same amount of ND to get that image in where you want it.
But, as we all keep saying, this is a preproduction model. The final model could be better or worse on some aspects.
I really don't know the answer to the how sharp a lens needs to be for these cameras. It's really quite confusing, even more so in the case of the F3 which has such conflicting sensor info out there... from 3.6 to 12+ MP. One thing I do know is that better glass also has better contrast. That's one of the reasons why the image looks like it pops.
But you are very right, it's a preproduction model, so we really just have to be patient.
For me, I stopped reading online about glass. Not that I don't get a rough idea of what others thing per say, but I make no absolute decisions based on it. When I want glass, I go rent it or use it at a local shop to try it out first. I've used everything from $5k lenses to $120 lenses on my 7D and AF100. One thing I learned, in the sub $2k range, price is not indicative of performance.
Seeing some of the night shots at 30dB with what I thought I read as at least an F3.5 or F4 lens was OUTSTANDING. At night, with my 7D, I could never go beyond F2.8, and even then, it was noisy. I generally shoot night material at F1.4 or F1.8 on both the AF100 and 7D. From these initial tests, it looks like you could get away with some slower glass.
I thought people didn't want contrast? Everyone is always minimising all the contrast settings in camera but then they want better lenses for "more contrast" what?
Yes, this is a big contradiction. Contrasty glass (modern and costly ones) are good to the eye from a direct output, but in the end it make you loose quite some dynamic range. More so when you think that you can adjust contrast very easily in post. It is more flexible and much more precise. With the appropriate tool you can selectively choose which part to make more contrasty and not let the sky blow out for example.
Welll.............
i dunno. A low contrast lens is also milking up the detail in the blacks, muddying up the exposure and probably spreading an even cast over the whole image..... A contrasty lens is "clearer".
because until the last year or so, prosumer cameras have only had about 7 stops of lattitude. Flattening the image helps mimic the 11+ stops high end HD and Film shooters have been enjoying for years.
But with cameras like the AF100, F3, FS100.... Contrasty lenses are a good thing.
So the FS100 has "Highlight problems".... please. There is not a digital video camera made that does not have "Highlight problems". If you overexpose and peak the highlights with a digital video camera, whether it is a Canon 7D, a Panasonic AF-100, a Sony F-35, an Arri Alexa or a Sony NEX FS100 it is going to look like sh*t. The differences between the cameras is the parameters where and how that overexposure and peaking happens. Our jobs as cinematographers is to understand those parameters, abide by them, and expose our images properly. If the highlight handling characteristics of the FS100 is not something that you like, then it would be advisable to use another camera. If you can find better highlight handling characteristics, and comparable image quality, in a camera that costs $6000.00, then please, share that with the rest of us.
