Baby F3 aka NXCAM S35
>100 lines more res
no moire
less aliasing
less jello
1080 60p
1080 hdmi
About bit depth:
8 bits does limit the creative expression or at least it makes shooting harder in many cases.
Otherwise there would not be more expensive camera with bigger bit depth.
It always helps when you have headdroom to burn.
This would have been almost impossible to shoot in any other than negative film:
http://www.youtube.com/watch?v=lAAvkCNC-CE
Also, when your camera's latitude increases, you need more bits.
If you put 7 stops to 8 bits, you have 36 levels of gray in one stop.
For 12 stops thats only 21 levels per stop.
For people asking where do you need additional bits, go outside in sunny weather and take one backlit photo with dslr which has shade and sky. Compare raw and jpeg. If you want to see both shade and color in the sky, you need more bits than 8. Or you can bring light equipment that cost 10 times more than the camera and make it even for 8 bit picture.
Better question in general would be, after 2 decades of digital camcorders, why are we still stuck in 8bits and interlaced picture?
About chroma resolution:
When you people say that 4:2:2 is so good and 4:2:0 is so bad, are you meaning just with interlaced material?
They both have same horizontal chroma resolution with progressive material.
Could someone summarize what else I get more with fs100 than 5d2:
1) 2 xlr's
2) a bit more efficient codec
Let's see (including what others said)
EVF and articulating screen
Overcranking/undercranking
720 modes
Cleaner picture with minimalized aliasing, no rainbows
Cinema gammas...and many other extensive picture controls
No time limits
better exposure/focus indicators
less skew/wobble
more function buttons/switches
cleaner gain section (from what's been shown so far)
Yes...XLRs and better audio, period.
Yes...a better codec/ proper imlementation
shallow flange distance allows for more lens options through adapters
HDMI out is better....maybe even WAY better....don't know fully yet.
No need to worry about heat degrading image quality. (This has been reported on the 5d by many users...some have never seen it)
What ASG said...1080 60p
I'll bet I'm missing a few....Oh yeah better resolution, timecode out of HDMI...
Had some hands-on time with the FS-100 today at the EC Pro Video demo in NY. It was presented by Juan Martinez. A few interesting tidbits. They were showing one unit with a prototype of a PL adapter, with a Cooke Panchro. Taking that image to a Sony OLED monitor. Gorgeous image. The most interesting news is that Juan confirmed that HDMI is 8-bit 4:2:2. The most interesting news, though, is that the HDMI also is switchable to a 4:4:4 8-bit RGB output. This was not included in the initial brochure. In other observations, I have small hands so I didn't find the buttons as much of a problem as one reviewer had complained. Shooting in the darkened lower level of EC Pro the camera was set to +15db gain and it was virtually noiseless. I have no idea what picture profile, if any, was selected and what other tweaking might have been done to the camera. I'm very impressed by what I saw.
O.K... Not quite April 1 here on the East Coast, but it is in Europe. Does that count with the 4:4:4???
The viewfinder eyepiece is the same as the EX-3. LCD screen is decent and more than functional. If trying to handhold, best to attempt it holding camera against your chest. The handle and grip remove easily and while there seems to be a little play in the top handle's attachment to the hot shoe, it is sturdy enough. I think it would need some sort of rig to use handheld. But since it is so lightweight, it would also balance easily on a lower end steadicam-type rig.
I questioned Juan several times about the HDMI. Yes, there is a menu-switachable option for 4:4:4 8-bit over HDMI. Default output is 8-bit HDMI 1.4 with embedded timecode.
The one thing you will need if you want to go shoulder mount is another EVF, just like a DSLR. But then the existing EVF would work fine for a focus puller.
Opinions on the "feel" of the buttons varied with each person who held it. No consensus on that. I thought they were alright, others not so much.
One of the things talked about during the demonstration is that glass will make or break this camera. From what I saw, from the demo stuff, that
appears to be true.
Because this camera does not have the processing capabilities of the F3, it can be easy to blow out highlights. That was demonstrated not only in the test footage,
but live during the event. Scenes/lighting that were easily handled by the F3. An external ND filter will be a necessity for bright light/high contrast situations.
One thing I noticed is....we have not yet seen just what this camera is fully capable of. It will be interesting to see what the 8bit 4:4:4 footage will look like.
What I said about the highlights, I don't view that as a negative. It means your lighting budget for interior and night scenes just got a lot more affordable.
Having to add a filter and stop down a bit for daylight isn't the end of the world.
The one and only thing I would change on this camera is to make the EVF removable. Mount it to the body using screws like the mic. Have a custom cable
so an operator could mount it on a shoulder mount or cage. just my .02.
Correction, 2 things I would change. Not having ISO settings (Gain only) is just plain silly, especially since they are trying to attract HDDSLR users.
I know people can correlate gain to ISO, but since DSLRs and other video cameras in this class offer it, Sony should too. Hopefully a firmware update
can take care of that.
I'm guessing none of the people complaining about Sony "choosing" to omit an ND filter wheel have ever seen an e-mount camera. There's no way! The flange distance is, like, nothing.
E-mount is 18mm, isn't it? m43 is 20mm, and the AF100 has it, so I doubt depth was the biggest issue. They could probably have made it as far as depth goes, or at least come pretty close. It was my understanding that they were saying they couldn't fit it because of the body size -- as in, there just isn't enough room to make a circular wheel with three or four filters on it that are the size of the sensor, not depth-wise, but width-wise, within the FS100 body.
I don't recall anyone ever complaining about a lack of ND filters on the DSLRs. Maybe it's because I'm not a video guy but I don't know what all the fuss is about. There is this quirky invention called a mattebox that's been around for I don't know, about a hundred years?
For me it's about having a blow your mind S35 sensor and uncompressed output in a small reasonably inexpensive package. Wasn't it going to be called Scarlet? :banned:
I understand that some pro users want and/or need more options, well you can have them just spend more money or get a smaller sensor. For my filmmaking purposes I would have been happy if it had no sound recording onboard for $1000 less but I'll take what I can get.
Id agree with you but im spoiled by my af100's nd filter...
Bottomline, the fs100 for me is like a confused little camera... A video camera trying to be a dslr
Sony has said this camera is in part aimed at the wedding/event market, so the omission of the ND filter wheel can be a big deal. I'm for the most part not looking at this camera anymore for that reason... carrying a stack of ND filters around a wedding will only make life more complicated.
I really don't see the lack of ND on this camera as that big of a deal. While I would use the camera more in controlled situations, I would definitely get a run and gun/event configuration set up for it. What I was planning on doing is picking up a used Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF lens (and use it all manual with a F mount to E mount adaptor) and then just picking up screw on ND4 and ND8 (Maybe a ND16 also, to mess with DoF more in bright light) filters for that lens. I think that kind of combo would make the FS100 a rootin', tootin', run and gun shootin' son of a gun! An ND8 will knock the native ISO of the FS100 from 800 to 100 (at 0db). If it is really giving a workable 10 stop DR, then daytime exposure should not be that difficult. Would it be as convenient as an integrated ND wheel? Of course not. However, it is a compromise that I would be willing to live with for being able to have a camera with a Super 35mm sized sensor, designed for a $13,000.00 CineAlta line camera, for under $6000.00. If that is something that you are not comfortable with, then there are other cameras. That's very cool.
Don't get me wrong, it's not a knock at the camera. At $6k it's a steal for all the reasons you described, and I'm looking forward to seeing what others will do with the camera. But for me, I'd rather not have to worry about screwing and unscrewing an ND filter as needed and carrying them around with me for the few weddings I do a year. I'm sure for 95% of folks who would be looking at it, this borders on being a non-issue. I'm just the other 5%.
Like I said, that's cool. RIGHT NOW, I think that choosing between the FS-100 or the AF-100, or staying with HD-DSLRs, or going big with the F3, really boils down to personal preferences, individual needs and available resources. I am comfortable with Sony products; spending most of my SD years using them. I made the switch to HD by going to HD-DSLR, and I am done trying to man handle those types of cameras into video shape. I am excited by what is now available. I am going to go with the FS-100, when it is available. That does not mean that I believe that everyone should. Even with that, I am sure that the FS-100 is not going to be my last camera and can't wait to see what the future brings.
Yeah... my first TV job was in '98 when I was 19 and the station was using the first generation of DVCPro cameras and everyone was amazed at how good it was for how cheap. Now for less money you get the F3. For a lot less money you get the FS100 or AF100. Heck, my HMC150 blows it out of the water. And this is less than fifteen years later... fun times :)
