http://avid.com/products/xpresspro/featurelist.html#partners
No word from what I can see on direct support for p2 cards and/or MXF.
David S. said:http://avid.com/products/xpresspro/featurelist.html#partners
mcgeedigital said:Really?
Native DVCPRO HD: 1080i/59.94, 1080i/50, 720p/60, 720p/24
Panasonic P2 support
It's right there.
OliverM said:One tricky thing though. Watch out with os-updates. The X-presses on mac I know do NOT like updates in os nor QT. Apparently if you update QT to a newer version, X-press won't export Qt-movies anymore. That kinda bugs me aswell. Most other apps take advantage of the built in Quicktime core in OsX. I mean, if you update or install more codecs you gain quality and options in other apps. Not with Avid...
carlone said:Anybody doing this professionally should be aware that if you contantly update your OS to stay on the bleeding edge sooner of later you'll get burned.
David S. said:Updating to correct bugs is in the normal release schedule for Windows and the MacOS.
It's hardly "constantly."
Tiger was released last year, and Leopard won't be released until next year. That's two years between releases.
In the meantime, AVID has introduced numerous updates to its software as have many other companies.
Scott B said:After upgrading to XP 5.5 for Mac, I am unable to import MXF files. I have several hours of DVCPRO 50 and HD material shot on P2 cards and transfered to drives.
Any suggestions?
I would like to retain the original time code of the clips to facilitate syncing with other (DVCPRO 50) cameras and audio in an Avid Unity environment.
Seems crazy to have to lay the material back onto P2 cards and output through the camera to tape...
Any suggestions?
