Andrius Simutis
The difference between not bad for a single shot and useable for an entire documentary is huge. I only watched the beginning of your clip, but I heard all the traffic noise. Try recording your friend talking on a busy street and I doubt it would be useable for a documentary where you'd have to edit a bunch of voices together and have them sound consistent.The audio recording straight to camera with the internal mics is really very good. I wouldn't want to use it for everything, but listen to the voice in the beginning of this test. Also listen to the audio in the final clip. Other than wind noise in other parts, I'm impressed.
The Tascam DR60, the one that can mount to the bottom of the camera sounds like a much better option. You can still feed the camera and that recorder can be your safety, and even double safety since it can record two copies with one being lower level to save you from distortion if someone suddenly starts yelling. The key is that it can be attached to your camera so that it's not another piece of gear to set up and carry around.
For interviews audio is too important. If it was just a skateboarding video or camera test, sure, use whatever you got.
