I bought this AC adapter even before I got the DCC8 coupler, following your link.
Now I got the DC coupler : It was not working for me. The plug of that adapter is not fixed with the DMW_DCC8 at all.
After looking around the house, I found an old AC adapter for portable dvd player, rating as Out Put DC 9V 3A. The plug of this old ac adapter fixed perfectly with the DC coupler. Is it safe to use this adapter?
I think there is a problem generally with using adapters that have max output voltage of only 8.4v. Some work and some don't, there's some variance even of same model of adapter.I use this adapter all the time. They must have sent you the wrong one by mistake.
Someone in another thread (I think person who was making external "power brick" battery solution), speculated that the way the camera distinguishes between battery and adapter is in fact by the voltage level at the terminals.The battery itself only puts out around 7.5V at full charge. The unit can tell the difference between whether you have a battery or adapter plugged in. I think the "this battery cannot be used" is a generic error.
I had the same issue, I bought the Rhino and it didn't work for me. The Adapter in question in this thread is a 9.5v and it works great.I think there is a problem generally with using adapters that have max output voltage of only 8.4v. Some work and some don't, there's some variance even of same model of adapter.
I just got the Rhino 2500mA adapter and at 8.4v the camera gives me the message, "This battery cannot be used." I know some other people have successfully used the same model of adapter.
The problem, from what I gather, is that the GH2 battery supplies 8.4v while the GH2 adapter supplies slightly more, around 9v. That way the GH2 can tell whether it's hooked up to battery or ac adapter. When you use an adapter that supplies only 8.4v the camera thinks it's a non-Panasonic battery and refuses to work, so you need to make sure you get an adapter that can supply slightly more than 8.4v.
Thanks. And just to be sure: that 9.5v adapter you link to uses the same connector tip as that required by GH2's coupler?The Adapter in question in this thread is a 9.5v and it works great.
Thanks, doesn't that fit pretty close with what I was saying? If the voltage is higher than max Panasonic battery voltage the camera assumes it's running off AC power and doesn't check for Panasonic battery compatibility. But if voltage is less than max battery voltage the GH2 assumes it's running off a battery (even when ac adapter is connected) and does a check for proper battery, which it doesn't find if an ac adapter is being used, thus resulting in message, "This battery cannot be used".. . . the UVLO voltage will always be higher than the max battery voltage which is why I think the unit wants a higher voltage from a non-battery source.
now that is DIY.
