Matt Gottshalk
Resident Preditor
From Off Hollywood.
"But the REALLY BIG NEWS is the Ki PRO. At just under $4000 this is a tapeless video recording device that records high quality Apple ProRes 422 Quicktime files direct to disc. SD/HD-SDI, HDMI, and analog inputs. An olptional "exo-skeleton" puts the unit in a chassis that can both on a tripod with the camera.
Many cameras have outputs that bypass on-camera compression - so, for example - if you take the 10-bit HD-SDI feed from a Varicam into the device - you would record higher quality files that the actual camera is capable of.
Another obvious benefit is that some shows use a variety of different cameras and recording formats. Using Ki Pro's would allow all media shot to be in 1920x1080 Prores - ready to edit.
I'm most excited about using this as a dailies solution, and an an on-set playback system."
