The comments just say CineLike V with a slight highlight adjustment in post.
They also just replied that he was using factory scene 5
Like thenFS5 too, but you have to change lenses or buy an expensive zoom to get going. And the media is expensive too..so compared to the dVX200 there are still some things to consider. I understand your arguments for choosing the FS5, but I still think it is to soon to absolutely rule out the DVX200. Time will show. Maybe the DVX200 will shine a little more some day...hopefully before christmas...
And that maybe someday the footage will be nearly as clean as my Canon 5D MKIII.
Got one unit few days ago
FOCUS RING
Dragging noise when using with left hand. No noise when operating with right hand and right side of the camera. Weird. Anybody else?
WHITE BALANCE
I have hmc81 hmc40 and ac90. When I take white balance with those they are very natural and comparable each other. DVX200 is from other planet - unnatural and bluish. Also tested another dvx200 and wb was very different compared to old panasonics. All tests done in factory settings and scenefile1. Weird.
Well there is great color correction settings in menu but why I (why not pana engineer) should do the calibration.
Has anybody tested two units? Are they comparable in colors or are the units "color individuals"?
FOCUS RING
Have up updated to the latest version firmware 1.25? More importantly have you loaded in Barry Green's scene file with 6 new scenes? There seems to be a difference in color in mine since doing both of those. All of this information can be found in posts above if you have any questions about doing both of those things.
Yes. The focus ring is touching the part between focus and zoom ring in left side, and make noise (rub).
Have you thought to send your unit to warranty service? Maybe someone did it already? Did they fix it?
I am afraid that the focus ring may wear out and produce dirt (aluminum or plastic) inside the ring.
HD version is here" https://vimeo.com/148010166
Here is a four minute clip made with the DVX200, with the latest firmware and Barry's Scene file 3 (for the GH4). This was recorded in AVCHD (I had special reasons for doing this) at 60fps, 500 iso, with careful attention to the waveform monitor. The conductor's bald head is very nearly white, but not quite. The waveform never went to 100% and most of the time was at around 80%. At the end, I wanted to show the entire orchestra, so I flipped the gain to high, which does result in some blow outs. I also did a careful white balance with a white disc on a music stand next tot he conductor before I started. I am very satisfied with the result except for the fact that there is not much midrange exposure. Would you think there should be? Should I haver raised the pedestal from -8 to 0?
I can see it is not there on the FCPX scopes. I tried increasing the midrange but it destroyed the look, so what you see here is completely unmodified except for the compression of uploading the pro res file to Vimeo. As i said, I am happy with he look as is. This clip seems to look best when played back through Apple Safari. It looks darker in Firefox. Audio was from the Panasonic shotgun mike attached to the microphone holder.
Thanks for sharing. Couple of things I noticed while viewing on my computer screen playing from Vimeo:
The shutter speed looks high? This might be an internet/Vimeo thing but when the conductor is moving his hands it has a somewhat staccato feel. Don't know if that was what you where going for or not. I usually shoot 60p at 1/60th for things like dance or general human movement for smooth motion.
The mids to high blacks look crushed to me. The orchestra looks like they are performing during a power outage.This looks very "DSLR" in my opinion and why we would want to by a DVX200 to rise above the look of that era. Opening up the gamma will create a more inviting look to the footage and allow you to lower the exposure for the highlights and not have the scene feel underexpeosed. (I don't mean the grey milky look either).
Imho, where video cameras true metal lies is how they handle the mids to high blacks. I call it an open gamma, but it is the range of tones that make rooms feel bright or dark with the same exposure. Pedestal is part of it but not all of it. Beware, computer screen are notorious for making blacks look darker than they really are. So it is tough to know what to trust when adjusting.
I concur about the blacks looking crushed and the staccato feel. I think shooting a lot of black clothing under bright lights while trying not to blow out skin highlights isn't helping... just looks like it might also be a deceptively difficult shooting situation. But, both of those things seems should be relatively easy to fix. Overall though there is nothing "off", really, about the image. It looks good overall.
The DVX200 does have a setting exactly for that, it's called BLACK GAMMA. In most of the GH4 scene files I had to crush down the black gamma to get it to render comparably to how a GH4 does. You can restore it to default or even open it up all the way if you prefer that look.Opening up the gamma will create a more inviting look to the footage and allow you to lower the exposure for the highlights and not have the scene feel underexpeosed. (I don't mean the grey milky look either).
