AF200 Soon?
No camera for grown ups will ever use off-the-shelf SSDs. SATA ports are the flimsiest thing ever invented by anyone ever. Makes mini HDMI look like lemo. You'd get to use each SSD you bought about three times.
That is complete BS. We have been using the same two REDMAG SSDs (which use a SATA connector) since the Epic came out (which is such a childish camera, right?), and have had no problems, and use those mags often between out Epic and Scarlet, with no problems. I have used the same two SSDs for my samurai for a feature shoot, a short, and several freelance projects over the past two months, again, no problems with daily use for two months. I have re-used each of those off the shelf samurai SSDs about 40 times in the past two months. I also have a stack of regular HDs that I use with a SATA reader that I have been using for years, again, no problems. I don't know how you are pluggin in your SSDs, but if they are only lasting three uses, the problem is you and not the SSDs.
I think you'll see the GH3 before the AF200. Goggling around, you'll start to hear about the AF100's replacement will be a months after the GH3 announcement. Its all still speculative, just goggling around finding bits, pieces and rumors.
Just worked with a well-known Rapper here in Atlanta, nice size crew(About 6), lots of lights (no HMIs) with an specked-out, a AF100 (PL Lens) and two GH2s. I was very surprised. Upon arrival on set, I expected to see a RED.
FWIW, the pre show emails I've been getting from NAB have paid-for blurbs from Panasonic touting the AF100. Doesn't look like they are going to replace it at NAB.
I can't imagine less than a two year cycle on the AF100. If they announce or even hint at something at NAB, would it come out before 2013? I think not personally.
