and as far as color goes:the camera noise level is quite low
Performance was judged to be very good.
The effect shown is not severe, and is a great deal better than most CMOS
cameras exhibit. Clearly, something good has been done in the image processing to minimise the effects, the unpublished Panasonic document on the camera claims that ‘high-speed scanning’ has been used, clearly it works. If the shutter is set to a more sensible speed then the
effect is far less visible.
This camera does not perform particularly well at HD. Clean resolution is limited to about 1210x680 by the presence of high-amplitude spatial aliasing. This is a little disappointing from a camera with a large-format sensor, and indicates that optical low-pass filtering is either absent or inadequate, and that the scaling from the resolution of the sensor down to 1920x1080 has not been done in the best way.
Noise levels are rather high, even though the pixel size is that of a conventional 3 sensor ½” camera.
Sensitivity is also similar to that of a ½” camera.
Well, as far as I know, yes... but even then, it's odd, because after Alan submitted his report, CreativeVideo.co.uk tweeted that the AF101 had been approved by the BBC (as long as you used the Nano at 50mbps+, because the BBC HD requirements demand 4:2:2 color sampling). Since then, I haven't seen anything official, so ... I don't know where creative got their information from. I haven't seen any official announcement from an official BBC source.Are we still waiting for official word from the BBC re: AF101?
The AF101 is not a perfect camera but I haven't noticed any aliasing in my footage.
Yes, the diagonal resolution of the images on page 9 of the BBC report is excellent - virtually no aliasing at all! So perhaps...So why is the diagonal resolution so much better? Diagonal lines are what usually causes aliasing.. Does it make a difference in real world sharpness if the 800 lines are diag rather than vert?
Alan Roberts said:If the figure of 12.4 million pixels were to apply to only the active image area, then the down-scaling ratio to get to 1920x1080 would have to be 4,692/1,920=2.443,75:1, which is a very strange number to have been chosen deliberately. The complete lack of coloured aliasing in Fig.1 is a clear proof that the resolution of the red and blue subpatterns on the sensor are each greater than 1920x1080, and this calculation estimates that the actual pixel counts for R and B are 2346x1320. Thus, it is very odd to have such a high level of luma aliasing in the image, since there are plenty more pixels on the sensor than are needed to get to 1920x1080. It is very obvious that the scaling has not ignored (skipped) sensor pixels, since that would have invoked coloured aliasing, both horizontally and vertically.
