themagickite
But since the AF100 is primarily a video camera (to the point that it apparently won't capture stills at the full resolution of the sensor) I think it would be more appropriate to use Barry's Cinema Crop Factor of 1.18 instead of the still (photo) crop factor of 2. So the 28mm lens in your example would be ~33mm.
Yes, there's currently still the drawback of manual operation only with a mechanical adapter. But if/when the electronic lens adapter comes out...
Mark
it actually still has the same crop factor of 2
the gh1 uses a larger than normal sensor, but all the 4/3rds lenses still produce the same size image circle so it crops around to the image circle a 16:9 or 4:3 or or 3:2 or 1:1 image. The af100 will only be 16:9 of course.
To put it this way, if it didn't use this method then producing a 16:9 image from a 4/3rds sensor would have yet another crop factor.
does that make any sense?
i actually really like the 2x crop factor, it just makes everything really simple if you're used to full frame focal lengths, but 1.6 is troublesome to think about, not that it really matters, i guess people are complaining cause they it can't go as wide and not the maths,
