Alpha Beta Omega
I checked my LCD screen and it's pretty much spot on. No green bias just a tiny bit warm. I do think my Marshall looks cooler in temperature when having it in neutral but both tungsten and daylight looked great.
Have you shooted using the 3.2k preset? My 5.6k preset is OK, but 3.2k preset is greenish. It is more evident shooting wood that normally has a pink-orange castingare you checking it under tungsten lighting with the 3200 preset? Because we tried two cameras and both gave us a slight green tinge.. The marshall is a bit more on the magenta side but that's the calibrated monitor and both af100's exhibited the same greenish color on the lcd.
Even the GH1 and GH2 allow you to adjust the color balance of the LCD (Setup menu, Tool icon, Montior, press Display button). How could the AF100 not allow this to be done? That is ridiculous. Panasonic needs to fix this so that we can properly light and set up our shots.
Let me add my 2 cents here as well. Received my unit today and it was the first thing I noticed, the LCD is biased towards green- quite a bit. The EVF is fine. There are a few instances in the manual where it states not expect the EVF and the LCD to match.
At least they warned us
bill
There should still be an adjustment for the color balance of the LCD. If a $1000 DSLR from the same manufacturer has it (I don't care if they're like 2 separate companies, they both say Panasonic on them) then the $5000 camera that's supposed to be PROFESSIONAL should have it.
