Mine cam with 2 pair of rails. Some really short ones and some longer ones. Looks like they might've forgot a pair.its just the same one as Erik Naso posted already, with same splitter and battery......
1 question How many Rods was supposed to go together with Tilta baseplate? i got only 1 front pair, as i thought it was supposed to me 2 pair of rods..... 1 front and 1 rear.....
am i missing one?
am i missing one?
Can anyone confirm the lens port diameter on the Tilta Mattebox for me? I've read conflicting measurements of both 110mm and 120mm, and I need 114mm for my CP.2s.
Cheers
what follow focus would u suggest? its seems like my rods are kind of low and its a big space between rods and lens, my original choice was Lanparte but now its seems like it will not work, same as tilta ff
i moved the rods clamp as high i could, maybe i could turn it up side down but looks like it will give me just a few extra mm ..... any ideas? (so maybe there is a little draw back after all in tiltas design )
From my experience the Lanparte follow focus is really nice and has made my life much easier when critical focus is necessary. It's quite the solid piece of metal, and is a little heavier than the competition, but I really don't mind as it's very manageable. As I said before, quick release mount is a must, and the hard stops make focusing with some of my crummier EF zoom lenses more precise and an altogether better experience (Tamron 17-50mm).
Comparing it to a Zacuto FF, altogether I like it better - heavier, but the dampening in the Lanparte just feels better to me. The play is minimal - less than a half of a millimeter, though some of this may come from the rubberized gears flexing a little bit. I think you can take it apart and adjust the way the gearbox meshes. I don't think you would ever notice it in actual use.
I did have a tiny bit of lateral wobble between the grip wheel and its axle (again, no more than .5mm), nothing that affected gearbox play, but a little annoying. I went to the hardware store and found a $0.26 black plastic washer for the grip wheel to ride on - problem solved.
Overall a pretty nice piece of kit for the price, and it's working well with all my other gear. There doesn't seem to be anything else out there that competes besides the Tilta FF.
Bottom line, I'd recommend the Lanparte.
here is a picture of the parts of my tilta rig that I use. When I go hand held obviously I attach the hand grips. I've had to space it out and move the camera forward so that it's comfortable to use the follow focus, and the battery plate and wireless receiver in the back act as counter weight when hand held.
As I was told by the engineer at the factory, the rig is made for a Chinese person, who is generally smaller than westerners, so I feel a little scrunched when using it, as I have broad shoulders and long arms... but it's not so bad. Definitely a step up from the old dvtec rig I had. I'm actually really pleased with the performance of the follow focus, a lot more than I thought I would be at least.
From what Huang and the engineer told me at the Tilta factory, they used to be partnered with lanparte, using the same c&c facility and factory floor. When Tilta moved out, Lanparte poached their second gen designs on all of their stuff. Tilta is currently in their 3rd gen of design, and I think it shows, for the most part at least as far as the rigging ergonomics are concerned.
Enjoying the Tilta Baseplate. Went with the short handles and follow focus from Lanparte, but I think a small counterweight may be in order to balance out the monitor.
Hi Nate, what QR plate are you using to attach the baseplate to the tripod?
There is a set of 3/8" and 1/4" holes on the bottom of the baseplate by the v-mount. I just threw a Manfrotto plate on it and it works great.
Regarding the Tilta arm, it works better than those other cheap arms (as it has a rosette), but it's not quite to the point of a Noga Arm for heavy lifting. A DP4 is fine, but I wouldn't use it with a PIX240.
