Darren Levine
while DSLRs have an open/close mechanism, it isn't actually the shutter, the shutter is electronic and there is no noise because nothing is moving, but in any case, the af100 won't have any moving parts either
There is no physical curtain shutter in the AF100 for video usage. The AF100 isn't a stills camera so it doesn't have a mechanical shutter. It can capture single 1920x1080 frames, but that's not the same thing.Does the AF100 have a mechanical shutter like a DSLR? I know that it doesn't record with one...
...I'm asking because I have to shoot some huntin' videos, and it won't do well if the camera has a shutter that could open and close - make a noise...yada yada.
Nothing that could make a noise in this camera my friends, unless you leave the "press record" beeeeeeep on.![]()
...if you turn the beep on it only beeps when your memory card is full.
It keeps coming up but many people including those above have knocked this myth on the head. I shoot 25p and monitor on a Panasonic broadcast monitor amongst others and there is no problem. Some of my 25p material is transferred to HDCAM and the engineers say there is no problem - all looks good.
Can someone who has "the issue" please shoot footage that shows it, and then post the original raw untouched card image? In other words, format a card, film something that has "the issue", and then zip up the entire PRIVATE directory of the card and upload it so we can see exactly what you're talking about?
I'll try to find the time for pinpointing the problem this week and will try to upload some of the problematic footage. I want to go through the jerky footage frame by frame to see if the problem is inside the frames or not. The strange thing is that the audio isn't affected, the clip where I noticed the jerky playback has a music track dubbed on it and the music plays back fine. That was another reason for me to believe the problem isn't in the software that's used for playing back the file, if it was the audio would stutter as well, right?
