Barry_Green
Moderator
Rolf asks a hard question, and Stephen answers it in terms that I can largely agree with, but not entirely...
Here's the thing. It's hard to judge DVCPRO-HD against AVCHD when using the HPX170 as a source, because the chips in the HPX170 don't deliver all the sharpness that would truly tax either codec. It would be a more-even codec test to compare on something like an HPX3700, where the chips are delivering every bit of data that the codecs could stand, so hooking an HMR10 AVCHD recorder up to the output of an HPX3700, and recording native DVCPRO-HD on the HPX3700, would be the way to tell just what the differences are, in terms of what the raw codec can handle. Or, alternately, plugging an HPG20 (in DVCPRO-HD mode) into the SDI output of an AF100, would let you know how the chips and codecs act on that specific combination of hardware.
So -- is AVCHD a "step down" from DVCPRO-HD? In some ways, yes, in some ways no. It's 4:2:0 instead of 4:2:2. And it's long-GoP instead of intraframe. However, it's also 2001-era technology, vs. 2010-era technology. So would it be fair to say that AVCHD can deliver comparable images as compared to DVCPRO-HD? Possibly. An intriguing question.
DVCPRO-HD is 4:2:2, but it also prefilters the recording resolution down from 1920x1080 to 1280x1080. AVCHD is 4:2:0, but it retains the full 1920x1080. So DVCPRO-HD will have twice the color resolution but only 2/3 the horizontal resolved detail.*
And DVCPRO-HD is bulletproof as far as motion artifacting, whereas AVCHD is a long-GoP codec. However, as a long-GoP codec, it's really good; I compared it against XDCAM-EX and found AVCHD to be much more robust regarding motion artifacts from cases where the codec gets overloaded. So while it isn't a true intraframe codec, it's much less susceptible to the issues that caused long-GoP codecs to get the reputation they got in the early days of HDV.
The ultimate is AVC-Intra. Intraframe, high bitrates, 4:2:2, and 10-bit color. That would be the ideal. But that requires P2 and 10-bit infrastructure throughout the camera, and that's not the AF100. I'd love to have that camera (an AF150? AF200?) but it would cost substantially more (Panasonic has said between $2,000 and $4,000 more) and just how many of us are there who would really buy it? 5%? 10%? I bet 90% of the folks out there, when faced with the prospect of a $4699 AF100 or a $8500 AF200, would choose the AF100. And that's what Panasonic has to look at; building a unit that will satisfy the market.
So - am I concerned about it using AVCCAM instead of DVCPRO-HD? Not at all. Like Stephen, I have found AVCCAM to be a perfectly satisfactory alternative to DVCPRO-HD. I would still choose DVCPRO-HD for chroma key work, but for general work, AVCCAM holds up very very well. There's no doubt that the images from an HMC40 or HMC80 (in good light) are substantially more detailed than those from an HVX200/HPX170, and the AVCCAM codec is robust with little if any artifacting. I've been using the HMC40 and been very happy with the recorded images it produces. If I was making a $100k feature film, I might invest $2k into a Ki Pro Mini; if I was making a $500k feature film I might invest $5k to get an HPG20, to get the absolute maximum best-quality codec I could get, within the budget. But for a built-in codec I think AVCCAM is a totally reasonable choice. I think those who are complaining about AVCHD, are in for a big surprise when they start using it. Panasonic avoided the whole HDV thing, because they thought that HDV/MPEG-2 just wasn't adequate for professional use. They caught a lot of flack for that, but they stuck to their guns, and now they're betting heavily on h.264/AVCCAM, because they think that finally there's an affordable low-bandwidth codec that delivers professional-quality results. Give it a try. You might be very pleased with what you see.
Discovery HD approved DVCPRO-HD for unlimited acquisition, editing, and mastering. I don't know if they've given any rating for AVCCAM AVCHD yet.
*edit: when I say "twice the color resolution", that's in terms of the ratio of color to luma samples. But if you want to be strictly mathematical about it, the advantage isn't quite as great as twice, because you have to take the prefilter into account. So truly, DVCPRO-HD's recorded color sampling is 640x1080, as compared to AVCHD's recorded 960x540 color sampling. That works out to a 1.333:1 advantage in terms of total color samples. But even then it's not really quite fair, because you're talking about truly twice as many on the vertical... and then, furthermore, it gets more complex in PAL where DVCPRO-HD is 1440x1080 instead of 1280x1080 so the luminance resolution advantage of AVCCAM is not as great, whereas the color sampling advantage for DVCPRO-HD increases from 1.333:1 to 1.5:1. so... intriguing question.
