evolvmedia
FYI, the Atomos Shogun will NOT output an HD signal while it is capturing 4K. I assume it will not output any HD signal while the 4K is engaged period. This to me seems like a huge design flaw. If shooting on the A7s in 4K you are limited to only viewing your shots on the Shogun, then you can not send an HD signal to another reference monitor (unless its a 12G 4K). I see this being problematic when using multiple cameras and in an environment where you need to send video to additional eyes i.e. a director or producer. Also I could have sworn that Atomos stated the Shogun would handle timecode? I assumed this would be done through the Lemo connector and the yet to be reveiled LEMO to XLR cable. Recent videos online show the (clunky) cable is only XLR audio I/O. I've had my Shogun on preorder since the end of June and I assume mine will ship this week. My gut is telling me to cancel the order, but I might as well get it and test it before I over react. Cheers!
Below is my exchange from Atomos tech support:
New Update:
Hi Damen
The Shogun does not down convert the output to 1080p, it passes through to the outputs exactly what is sent through the input, so 4K in = 4k out
Regards
Original:
Hi Atomos,
I heard something in an interview from your President that might be a little troubling assuming I understand it properly.
Can the Shogun while receiving a 4K signal via HDMI (from the A7s) or HDSDI from a camera like the A7s simultaneously output HD via HDSDI or HDMI? Obviously uses would be sending the output to video village or another monitor.
Thank you.
New Update:
Hi Damen
Regards
Original:
Hi Atomos,
Thank you.
