Barry_Green
Moderator
There's a readme.txt that should explain the proper procedure for getting the files to load. Make sure you're using the right directory for the right camera (USA, EU, etc).Can anyone get the scene files to work? I copied the private folder to a camera formatted card and tried to load them. All 4 files (extremes, flm lk1) showed up in the camera but when I tried to load it said it failed. Now for some reason after I reformatted the card I can't copy the private folder over from the CD. I wanted to just enter the scene files manually, as I want to save a few from each different group but it seems the numbers don't go up that high. In other words for the lolite, detail is to be 15 and my camera goes to 7. Any help?
As for the numbers, no, you can't just copy the numbers over because the numbers in the scene files don't correlate directly to the numbers in the camera menus. For example, the "15" for detail is based on the notion that "8" in the scene file = "0" in the camera. So "-1" in the camera is actually "7" in the scene file, and -7 in the camera is "0" in the scene file.
