7D vs MKII low light performance
squig
I've yet to see any conclusive results so can somebody do a quick test comparing the 7D @ f/2.8 vs the MK @f/5.6. With the 7D at say ISO 640 and 1250 what ISO does the MKII have to be set at to let in the same amount of light and which camera is noisier with those settings?
The only comments I've seen on low light compare both cameras at the same aperture settings which is pointless because the DOF doesn't match on the different sensor sizes.
Very pointless. Agreed.
I'd do it but my MKii went to Japan.
I still say the MKii is a stop more sensitive when matched. But I could be wrong.
And I'm still on the fence about selling my MKii. =T Stills are crazy.
Me too, I want 24p but until I can get some definitive low light results and magic lantern gets ported I'll stick with the MKII. I'd have to get a tokina 11-16 too to make up for the wide shortfall, can you make aperture changes with it on the 7D?
Kholi do you still have a GH1, or did you end up keeping hold of the 5D in the end?
I feel a lot of affection for the way the GH1 handles, but the difference in image quality is really quite alarming when it comes to colour rendering.
Can't wait for the 7D tests. That remains an option also, especially with the rather appealing new 15-85mm IS EF-S lens.
I have the Tokina 11-16 in Canon mount, the camera has full control over the lens (AF and aperture).
It doesn't have an aperture ring though. You have to use the controls on the camera for that.
--Xavier
I did extensive testing last week. Sadly I don't have the footage to post, but my findings were the following.
1. The 7d with all settings identical to the 5d is about a half stop brighter.
2. The 7d does worse with underexposure (more noise and loss of detail)
3. The 7d has more noise at the same ISO level but has less banding and weird artifacting at high ISO.
4. To my eye, the 7d has much more noise but a nice "feeling" noise than the 5d mark II. It feels much more like faster film stock than weird artifacted CMOS sensor imagery.
Both look nearly identical at or below ISO 320. I even found the dynamic range to be about the same. (wish I could be more scientific)
Perhaps this clip has already been posted, i don´t know... http://www.vimeo.com/6876905
5D is much sharper, look at ball 13 when it's resting against side pocket on the left. Have to download full 720p Quicktime file to tell the difference of course but quite a big difference. All to be expected from a smaller sensor I guess, with noise reduction working slightly harder. But all in all 7D is very acceptable. Clearly Canon have developed the CMOS technology further in the year that's passed since the 5D's release. A APS-C size sensor has no right to compete with full frame on such an even footing!
A well intentioned but highly flawed comparison.
5D was given a PRIME lens known to be incredibly sharp - 50 1.4 stopped DOWN to F4 - sweet spot.
7D was given a ZOOM (albeit an F4 "L" lens) lens shot WIDE open at F4. Add 1.6 crop, wide open, zoom, and the test is meaningless.
This test was probably done by a Nikon shill. ;)
...with regard to sharpness, that is. To be fair, the tester was more interested in low light capability, if I recall.
Totally agree that the vimeo test is useless. A 50mm 1.8 prime at f/4 is leagues sharper than an older model 'kit' zoom wide open. Not to mention that 70-90mm is actually the weak spot for the 24-105 which falls down after you get out of the traditional standard zoom range (24-70) :violent5:. Kudos to someone for doing the test at all, but...
I'm pretty confused by some of the statements being made about sharpness with respect to lenses. It seems a lens that is soft for stills might very well be plenty sharp enough for video...especially on the 7D.
Exactly. So if a lens is plenty sharp enough for stills, it's absurdly way sharper than necessary for video.
Hence, the idea that the lens was somehow soft and was making the video soft, is rejected. If a lens is soft enough to impact the video, it should absolutely *murder* the stills performance.
Well, that's the thing -- what if the aliasing could be gotten rid of, by some of those AA/moire filters? Once you identify what the problem is, you're then empowered to go find a solution to that problem. And maybe an FD adapter, with its optical element, might be exactly what's needed to soften the harsh edges and get rid of the aliasing... no way to know but to try it.
I've used minolta lenses with an optical adapter on the MKII, wide open the edges are very soft but stepped down a couple of stops things sharpen up quite a bit. The main issue is chromatic aberrations but I've done some outdoor tests of my kid riding her bike and the footage had this real 3D effect that you don't get shooting with a sharp lens.
