This technique is actually taught at marketing seminars - very sleazy...Also, when I received checks, they look like junk mail, so sort carefully!!!
Grant
I checked my rebate status on-line, and I was denied! I called, waited for 15 min. and finally got someone, who, you could tell, was over worked. Said that I didn't send in the bar code off the P2 Box. I said there was NO bar code on the box, but the numbers were printed below the serial, but NO bars. I said the same problem happened with some other guy's, and they had no problems. She said I was the first one that said that.
B.S. She said fax the front of the manual and write the serial number on the manual.. What good is that. She SHOULD have said, fax a copy of the P2 Card, because on the card is the serial number AND the bar code.
IDIOTS. really stupid idots.
This is what I am worried about, I called when I noticed that there were no bar codes on the P2 box and she told me just send in what you have. This was the same girl I spoke to the last time I called I think the name was Tayna. I told here the rebate form (which nobody bothered to proof read for the IS NO BAR CODES ON A P2 CARD BOX) wanted something that do-sent exist and I wanted to make sure my claim has no issues. I also called Panasonic and my local dealer, the Panasonic guy told me he could not help and only the rebate company had final say (so ask for something that doesn't exist then deny when some try s to do what you asked for but cant because they never could in the first place because your rule cant be followed because you want something that just isn't there). I can play by the rules, however very frustrating when the rules make no sense and the person on the other end doesn't know either.......
I have not seen any new A-Stock AG-HPX250 cameras arrive without the barcode/serial number tag like the one i took a picture of below.
Ultimately, your dealer and local Panasonic rep should be assisting you on this issue.
When you send in your rebate claims you must make copies of everything. I reccomend sending it in via certified mail.
