I'm not calling the poster stupid, the idea is stupid. It's stupid because it's useless.
The point Jim we're making is you've got a serious SERIOUS misconception going on here when it comes to your mental model of how time code actual functions in reality.
That's not relevant, though. Use whatever term you wish, I'm asking for a sub-$300 device that can record a single 4 channel file with what Resolve interprets as timecode. Whether or not's it's actually timecode, I don't care. What I get as timecode from the BMPCC and Zoom H4n is sufficient for my meager needs, even if it's insufficient for greater needs.
Can you understand that?
I think the trouble some are having is understanding why you need what Resolve sees as "timecode" if you aren't syncing to anything.
the product you are looking for doesn't really exist.
Because it helps to know which clips pair up. That's all I want it for. Nothing more.
It's not only a safe assumption that I do have a use for the device I'm asking about (or I wouldn't be asking for it), but I detailed out that use in post 10.
Additionally, such devices do exist, further belying the "useless" claim. I'm simply asking if a lower priced device exists, something under $300 new.
Jim, the cheapest recorder that offers everything you want is the TASCAM DR-701D at $500 new. It stamps TC and it records a poly WAV file. The TC clock, however, resets every time the unit is powered off, so if you want time of day you'll have to manually reset it every time you power up the recorder. Kind of a PITA, really.
On the plus side, it can sync to external TC through HDMI from some cameras, solving the clock reset issue.
If all you want TOD time code for is to have a way to visually confirm that your files match up, you're adding a whole lot of complication (and expense) for little return. I have done a lot of non-sync work, and there is a tried and true tool that makes quick work of file matching in post:
There are even useful versions in app form for your mobile phone or iPad.
FWIW I have run Tascam DR-60 II for about 6 hours on a $10 usb battery designed for phone use, and the USB battery still had power left. Don't know if this is an option with the Dr-701D but maybe a relatively cheap option to leave it powered up all day?
But they are NOT paired up accurately if time code does not match. It is as simple as that.
For reasons already explained it is pretty silly for a recorder to fill that TC field.
none of the professional sound people on this list seem to have an answer you want to hear.
Dave Fisk and Alex H answered it well enough.
"You'll...need to...increase your budget for a recorder. "
Thank you everyone.
Can you say clapper?
Not very practical for event work, though.
