puredrifting
Major Contributor
I have been using my mixpre 3 quite a bit. Far more than I would have thought because it is so limited and only records to one card.
A couple of thoughts on it. It is really great for run and gun doc shoots. I use it in a small bag with a couple of receivers and boom. I use the 1/8" stereo out to feed camera hops. If I need timecode, I just feed it using my wireless timecode system. A couple of medium sized L batteries will run it for more than an entire day and the big dials and lights make it easy to glance down and see what is happening with levels. I have a full size system, but I find the nimbleness of the MixPre 3 to make it so much easier use when I am running around with just one or two channels.
Tip: you can actually take the card out of the mixpre 3 and put it into a six series recorder in order to create a sound report. The mixpre 3 doesn't have this function right now, but it does allow you to name channels and create notes using the bluetooth app.
Great report, thank you. I am slowly talking myself out of buying the SDs or the F4 now because I don't want to work as a sound mixer really. I had to ask myself, "what do I need it for?" Yes, it has better sound than my C200 but I just shot an entire documentary with mics going straight into my C200 except for a few shoots where we had a sound mixer and the sound, for talking heads, is good enough. If you have a need for them, the new Mix Pres and the F4 are killer but you have to have a need.
I am shooting an interview next weekend with three subjects at once. I can plug in two lavs to the C200 and the remaining lav and a boom to my Tascam DR60 MKI. Won't sound as good as the Mix Pre but it's free and will sound good enough. I think I can even run the camera out from the DR60 MKI to the 3.5mm input on the C200 and record the third and fourth channels also to the camera 3 and 4 channels. So a Mix Pre or F4 is probably not in the cards for me right now as I can't think of a scenario where I NEED it. Sure, I want it, but I need to only buy gear that I need that will generate profit. Do you work as a sound mixer and get paid just for that?
