Have you tried de-interlacing before you export?
When you say 24P, are you talking about 24P native (edited in 29.97) or 24P Advanced?
What format did you shoot? What are your sequence setting frame rate and field order settings?
Noah
no. i was under the impression that video shot in progressive scan did not need de-interlacing. am i wrong?
I'm talking about 24P (non-advanced) edited in 29.97
What is the difference between 24p and 24p advanced?
Well, shooting 24p rather than 24pA, and editing in a 29.97 time line, means that you are working with (partially) interlaced video. While the camera was shooting in a progressive frame rate, certain frames will be interlaced due to the pull-down. Yes, 24p is designed for editing in 29.97, but it isn't true progressive.
24pA, since the pull-down is typically removed upon capture, will restore to a true progressive signal.
so should i just de-interlace my video then? what's the best way to do that?
Ok...I'm getting really confused... It seems half the people say to edit 29.97 when shooting 24p and to edit in 23.98 when shooting 24pa and the other half says to edit in 23.98 whether you shoot in 24p or 24pa
It's only because you originally shot 24p standard instead of 24pA. Please don't read this as being snappy; it's not -- I'm just being straight. I understand that you're new at this and I'm trying to help you learn.
What you should have done from the outset is shoot 24pA. The only times you should really shoot 24p standard is when you can't edit in 24p -- you don't have an NLE which will do it -- or when you're mixing with other footage -- 60i, 30p -- and MUST edit on a 29.97 timeline.
Otherwise, if you are planning for 24p and only 24p, shoot 24pA and edit 23.98.
Another reason people are saying to edit as 29.97, now that you shot 24p standard, is because FCP makes it a hassle to edit the 24p standard as 23.98 instead of 29.97. FCP can't automatically remove the 24p standard pulldown, so you have to remove it manually, using Cinema Tools. Every other major NLE will remove the 24p standard pulldown and let you edit as 23.98 with no problems, but with FCP, it's a pain, so people just edit as 29.97.
But if you do that, you'll have interlace artifacting in some frames. If you don't want that, then you have to remove the pulldown and just edit as 23.98.
Which is why you should shoot 24pA from the getgo.
(And frankly, because it comes up so much, I'll just come out and say it -- if FCP would get with the program and just let you remove 24p standard pulldown automatically, like everyone else does, then pretty much all of the confusion over this would just disappear.)
So, in the future, shoot 24pA.
For this project, if you want to get rid of the interlaced frames, you'll have to go back, conform the footage using Cinema Tools, re-edit the project (shouldn't be that difficult), and then you'll have only progressive frames; no interlacing issues.
Or, you can just live with it this time around and do it differently the next time.
Or, you could deinterlace, but you'll lose resolution by doing it, and you may end up with choppy motion or ghosting around moving objects.
