100Mbps Max Latitude Native 24/25p Patch
In my signature there is a link to emery's FPN reducing settings. People have varying success with them but on my camera they helped immensely. At high ISO you should also change the Film Mode to Standard, Contrast +2, Sharpness +2, Saturation 0, and NR +2. That film mode setting reduces noise the best on my camera. Also, this patch is probably the best for low light, in my understanding. Someone correct me if I'm wrong.
Are you sure about NR+2? cause i found out that that NR is doin nothin but killin details and not reducing noise so i keep it at -2
I never tried with sharpness +2 you think that is reducing noise also?
One last thing, am I understanding correctly that this patch removes the ability to shoot 720/60p? If so, what would be the ramifications of enabling 720/60p recording and leaving the rest of the settings as is?
The Max Latitude Patch configures the SH mode to shoot at 720p30 instead of 720p60 (and likewise shoots at 720p25 instead of 720p50 in PAL mode). If you attempt to set the SH mode patch back to 720p60, the camera will fail to record when set to SH mode.
lpowell and I had a conversation about sharpness and it does help retain sharpness in dim light. Don't turn it up in normal light, though. NR doesn't seem to have much effect on anything so I thought I'd use it for what it's called in hopes that it might help a bit. Whatever you set it at doesn't really make a difference in low light, just don't use it in normal light. The contrast is what reduces a lot of the noise, and the added sharpness helps restore detail that noise tends to mask.
I'm new to the hacked GH1 (been using a previously unhackable GH1 as a b-cam to an AF100), and I just did the hack using this patch. So far I've just shot a few test shots to make sure it worked. But I do have a question about reliability. I mostly use the GH1 as a B-cam during sit down interviews with controlled lighting. They can be anywhere from 20 minutes to 1 hour. Would the camera ever fail under these conditions with this patch?
yea i know contrast works good in low light and ok i will also set sharpness to +2 but NR gotta always stay at -2 cause in my opinion it's not reducing any noise and it's making small details looks blurry in low light and normal light condition
Only if you're interviewing a very quickly-moving tree. Before lpowell came out with his first patch, I was shooting interviews on the ptool's C settings, which are generally regarded as the least reliable of all. You'll be fine. I generally interview people on out-of-focus backgrounds, or just color gradients or on black, so I suppose if you had a really busy background with a very wide depth of field you could theoretically, maybe, kinda-sorta be risking it. But I highly doubt it.
For extended single takes longer than about 12 minutes, I recommend setting the camera to "H" video mode instead of "FHD" or "SH". The reason is that the SD card file system can only record AVCHD files up to a maximum data size of 4GB. In order to film extended takes, the camera seamlessly spans the video across multiple MTS files, and relies on AVCHD players and editors to reassemble the video during playback. This file-spanning mechanism is rather fragile, and can fail when recording at high bitrates. The "H" video mode records at a moderate 720p bitrate low enough for the camera to reliably handle extended takes.
Understood, thank you.
I stand corrected! :)
honestly I have not tested them against each other, though it could be the patch or the card but I have yet to get the EXpro to fail while I have got the extreme to crash with old patches and custom settings. And yes the GH recognizes them, man did I have a scare when I though it wouldn't work as I pulled it out but it did. Honestly I can't remember the numbers but I believe seeing that the larger cards preform better but it could be the other way, thing is I'm sure at this level of card you are well beyond what you should need for this level of recording (I think).
Happy shooting!
Yes can't wait to try this card with this new patch and see if i can make it crash.
And now i just saw this http://www.tomshardware.com/reviews/sdxc-sdhc-uhs-i,2940-12.html and the fastest cards are Kingston Ultimate XX i think they are way more expensive than extreme pro and can't find them on ebay.
I shot a 2.5 hour show last week in 1080p25 with this patch, with two cameras and it was superlative. Unfortunately, I found that I had monstor sized files to down-res to PAL DVD for the client, and rendering was such a ***** that I decided to shoot this weeks show in 720p25 (sh) mode. SH must stand for sh*t on this patch, because both cameras locked up relentlessly in the first half of the show. I got no usable files, and felt pretty embarrassed. I switched back to 1080p25 for the 2nd half, and all was fine again. It's not so bad as there's another night left of the show for me to film (pheeeew!)
The long and the short of it is - wow, what an awesome patch in 1080p25, but don't even think about 720p25. It stinks.
AVCHD or Mjpeg
AVCHD or Mjpeg
Thank you CColton, I will do some tests with what you suggest. But which codec to choose? AVCHD or Mjpeg?
Let me know how well it works for you. I've been told that MJPEG would tend to break up less in low light, but this patch is (apparently) designed to handle low light better, and I don't like MJPEG's lower resolution at all, so I stick with AVCHD. I avoid MJPEG generally; other users may have had better experience with it, but I just don't like it as a codec. Also, it has a recording limit, whereas the AVCHD options don't.
What's the limit? And, how else can you get 4:2:2 out of the GH1??? I thought 720/30P MJPEG was the only option for rendering 422
Limit depends on bitrate, in my experience it's been around 7 minutes. That's the only 4:2:2 option but I think 4:2:0 is good enough for the extra resolution you gain in 1080p. User preference.
Got my first and only failure in V2 100Mbps patch, was to be expected. But good news is it's completely avoidable.
I shot the Pappasarts Chart of Death (see below download it) with the kit lens zoomed and focus locked on to the chart on tripod with perfect exposure. Instant failure on pressing record button but file saved. Then did the same thing but with my hand over the lens when pressing the record button and removing it after 2 seconds. Recorded fully for 5 mins then i stopped recording. Streamparser reveals a huge I frame spike on the first file second I frame in. this caused the fail. This didn't happen on the hand in front of the lens file.
This patch is very robust in FHD mode and the likely hood of ever having to shoot something resembling the Pappasarts Chartb of Death in real life is not worth worrying about and if you do encounter it, you have the hand technique.
As lpowell say's, you must start with a freshly formatted card, i can't stress this enough.
I only did this test because i wanted to try break the patch as i couldn't fail it on anything else, even a full screen of sunlit gum leaves.
I'm having a problem with this patch not importing into Avid Media Composer. It locks up on import of files that have especially high bitrates (like the foliage testing I was doing). Also, is 20 MB/s fast enough for a card for this patch? It's a Transcend 32GB class 10 card with a reported write speed of 20 MB/s.
Ah ok. Would that still get me better quality though than shooting FHD on an unhacked camera? Or is there another patch that would suit my needs better? I'd like to shoot in 1080 if possible.
I think Mr Powell recommends the reliable patch for long event recording in FHD, but he should confirm that. Just make sure you have ample light.
