100Mbps Max Latitude Native 24/25p Patch
I LOVE 24k's video, really really very very good thang there. Absolutely brilliantly simple and looks like looks could kill! Hats(headress) off to you mista.
Thanks dude, if that's the case I'm gonna go stare at a zombie bank.
Hi! liking this patch, must try it out.
S. Matthews, which lens gave you those great greens?
Health & Freedom, long life for the community developers!
I am finding the patch to be almost 100% stable. Nice! I did get one failure out of a shot. For some reason, the shot would NOT record. I got the error message that "Card's Data Rate is Not Sufficient." Is that the error I would get from a "crash" due to the patch? Or is it truly telling me that the card is not sufficient?
Transcode to a lossless 4:2:2 codec like Avid DNxHD first.
Thanks for the suggestion but I am really wondering WHAT it is about this stream that freaks out CS5. Because all other AVCHD-streams (non-native 25p) from my GH1 are easy as butter to edit in CS5 natively without transcoding which is one of the reasons I switched over from FinalCut et al.
It could very well be something specific to my system, I smell something fishy with my BlackMagic Extrene Card...
Are other DSLRs using 25 PsF, is this native 25p something entirely different?
And... another question for 24k: which Kona Anamorph are you using, I am very impressed with its sharpness. Coudl you provide specifics? Was it (cough-cough)... expensive (sigh)?
Short Studio Clip with this 100 MB/s Patch
Hi!
Did a short Product Shot with this Patch. Max Bitrate was around 39 so this was no real stress test :-)
Overexposed the Highlights to check the rolloff in overexposed areas. I lifted the quarter tones in post to get more shadow detail and to see how good the latitude is.
I think it worked out o.k.
Thanks to lpowell for this great patch.
Well I used my kit lens the 14-45 f3.5-5.6 for most of it and a Rokinon 14mm f2.8 for two of the shots, so it's a mix.
Tried this patch on this very dark rainy day... just holding the stock-zoom out the window, maxed-out telephoto at this guy dancing in the rain. What impresses me is that in the original file ( I don't know how to upload 1080 to youtube) there is much detail in the shadows in spite of not-much-light (look under the trailer/wheels @ 1:30). And when the sun suddenly came out at the end, you can see that even in the white wall really is not clipping too badly. Thanks, LPowell!
Here is a video I shot with the new patch...
Thanks S. Matthews, this is an excellent example of what I mean by "max latitude". Even with the sky exposed for good cloud definition, there's more than enough bitrate available for capturing shadow detail in the foliage. While scenes like this don't need high average bitrates, individual key frames can easily require peak bitrates of up to 75-100Mbps. When the AVCHD encoder is set to a peak bitrate of 55Mbps or less, it will favor highlight detail over shadow detail, and be forced to produce mud in dimly lit areas when it runs out of bitrate. To cope with that issue, you'd need to shoot at a higher exposure, which would then blow out the highlights in the sky.
...I got the error message that "Card's Data Rate is Not Sufficient." Is that the error I would get from a "crash" due to the patch? Or is it truly telling me that the card is not sufficient?
If the recording failure occured within the first two seconds, it's likely due to a data spike in the second key frame. You may be able to help the camera through the start up period by initially covering the lens with your hand. If the failure occurs after four seconds or more, it may well be a write-speed issue with your SD card. In addition to using a fast Class 10 SD card, I recommend using the camera to format the card before each video shoot. This will guard against SD card memory fragmentation.
I totally understood why you liked my video after watching 1 second of your clip :)
Is this supposed to happen?
Lpowell, thanks for all the time and effort you've put into this. I'm gonna try the standard patch over the weekend and give whatever feedback I can. Cheers
No, those are corrupted frames of a type I haven't seen with this patch. Make certain the patch was applied correctly in the latest version of PTool. I'd be interested to examine the original MTS file.
I'm currently uploading the MTS file for you, stand by :)
I'll verify correct installation. Go to http://files.coltonvideography.com to download the original MTS file. Also, when I transcoded it to DNxHD to view in my NLE, the frame below and a few following it have strange artifacts that showed up.
These appeared at 20:15 (20 seconds 15 frames). I can't tell if they're present in the original MTS or not.
At http://files.coltonvideography.com I've put the original MTS file, the file transcoded to DNxHD, and the freeze frame above, as well as the stream parser screen shot I posted earlier.
EDIT: The DNxHD file is much larger so it's still in the process of uploading. As soon as it's uploaded it will also appear at http://files.coltonvideography.com
How should I be financially supporting this amazing hack community? I wanna donate a few bucks. I should support Vitaly probably huh? And Ipowell, by the looks of it!
Firstly thanks to http://www.dvxuser.com/V6/member.php?59441-lpowelllpowell and Vitally for their hard work and diligence and all involved with this help and testing in this project :thumbup:
I just tried the 100 MBs patch and found it to be a little unstable with certain shots. It failed a number of times on deep focus semi wide angle (28mm setting) shots particularly with green foilage in the frame.
All tests done using PAL GH1-K + Transcend 8 Gig Class 10 SDHC Card
Lens: Nikkor AF-28-105D Macro plus adapter. I chose this lens for its versatility rather than my prime lenses.
Settings: ISO100-ISO160, Shutter Speed 1/50th, Aperture F11-F16
In camera format done prior to recording.
Stats for each shot are from MediaInfo v0.7.35.
It was listing the footage in MediaInfo as progressive and these new clips are showing a frame rate of 50 fPS - is this correct?
Previously I have been using RAMBOCs 40 MBs patch and it lists the footage as interlaced with a frame rate of 25FPS. It is also describing the standard in both hacks as NTSC.....Is this normal or just a bug in the program?
JPEG screengrabs attached below to show the footage type.
Complete name : M:\GH13-100 MbS\GH13-100 MbS_Test_00001.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 18.7 MiB
Duration : 13s 775ms
Overall bit rate : 11.4 Mbps
Maximum Overall bit rate : 108 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : 27
Duration : 13s 760ms
Bit rate mode : Variable
Bit rate : 10.7 Mbps
Maximum bit rate : 16.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.104
Stream size : 17.6 MiB (94%)
No failure on recording
Complete name : M:\GH13-100 MbS\GH13-100 MbS_Test_00003.MTS
Format : BDAV
File size : 12.2 MiB
Duration : 3s 515ms
Overall bit rate : 29.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 3s 580ms
Bit rate : 27.6 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.267
Stream size : 11.8 MiB (96%)
Failure after 6 seconds
Complete name : M:\GH13-100 MbS\GH13-100 MbS_Test_00005.MTS
Format : BDAV
File size : 42.9 MiB
Duration : 10s 165ms
Overall bit rate : 35.3 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 10s 180ms
Bit rate : 33.7 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.325
Stream size : 40.9 MiB (95%)
Failure after 10 seconds
Complete name : M:\GH13-100 MbS\GH13-100 MbS_Test_00006.MTS
Format : BDAV
File size : 171 MiB
Duration : 1mn 9s
Overall bit rate : 20.6 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 1mn 9s
Bit rate : 19.6 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.189
Stream size : 163 MiB (95%)
GH13-100 MbS_Test_00001.jpgGH13-100 MbS_Test_00003.jpgGH13-100 MbS_Test_00005.jpgGH13-100 MbS_Test_00006.jpg
It seemed to cope well with the macro footage I shot but the footage with trees etc failed nearly every time after a few seconds. The traffic shot recorded for over a minute before I stopped it and the bus in the shot passed by full frame with no card write errors.
Write errors / class 10 card
Thanks, LPowell, for all your efforts.
I today tested the patch, and got several times write errors - the SDHC card should be faster... I used Transcend 16 BG class 10 card in FHD mode.
I feel that I have got less write errors when I use LPowell-Blackout 24/25 native patch (with GOP size = 15). I shoot in PAL mode.
Pekka
