100Mbps Max Latitude Native 24/25p Patch
...is this patch performing better in low light than "40Mbps AVCHD High Reliability Patch" ?
My 40Mbps AVCHD High Reliability Patch uses extremely conservative patch settings to insure reliability in even the most stressful shooting situations. In low light conditions, the GH1's AVCHD encoder reduces its average bitrate to levels that are too low to cause recording failures. When shooting dimly lit subjects along with bright, direct light sources (such as stage lighting), the 100Mbps peak bitrate of the Max Latitude Patch enables the encoder to pack the widest possible range of image data into each key frame. Make sure, however, to use a fast Class 10 SD card that has been recently formatted in the camera.
...so the short answer is yes, this will perform better in low light, because it will maintain a higher bitrate than the 40 Mbps reliability patch?
The 40Mbps AVCHD High Reliability Patch is designed with a peak bitrate of 44Mbps. This imposes a fixed limit on the maximum amount of encoded image data that can be packed into each key frame. When a scene requires more detailed key frames than that, patches that support higher peak bitrates will produce higher quality images. The 100Mbps peak bitrate of the Max Latitude Patch is the highest that the GH1 can reliably handle.
Awesome! And for reliable 60p, the 40Mbps patch would be best, correct?
I didn't find any thread talkin about the GH13 audio so i thought i might ask here also:
In Ptool you can change audio encoding bps from 192000bps to 440000bps and audio sampling rate from 32000 to 48000. By increasing these 2 values you will increase the quality of the audio recorded by the gh13 but i think then you wont be able to playback footage in the camera.
So if i add these audio changes for example to this patch or any other patch will that generate even more error camera crashing problems or it wouldnt change anything?
In GH1 AVCHD video modes, the built-in Dolby Digital encoder records 2-channel audio sampled at 48Khz at a 192Kbps bitrate. Listening tests have demonstrated that this level of compression provides more than enough bandwidth to encode the GH1's audio quality without perceptible degradation. The 440Kbps maximum bitrate supported by Dolby Digital encoders is not intended for use with a pair of stereo microphones; it's designed for encoding 5.1-channel surround sound programs, which the GH1 cannot do.
I don't recommend altering the GH1's stock audio settings in PTool. A number of dvxusers have reported that doing so undermined the reliability of the AVCHD encoder.
Yes, for the Max Latitude Patch I developed a new stabilization technique that delivers up to twice the peak bitrate of the Blackout-Powell Patch, at the cost of losing the 50/60p SH video mode. While the reliability of the NTSC Native 24p FHD mode is about the same in both patches, the PAL Native 25p FHD mode in the Max Latitude Patch is significantly more robust.
Ok, I´ll have to ask pretty much the same again, just to be sure I understand correctly: Changing the settings on the lower resolution avchd options interacts in some way with the encoder´s performance on FHD? Doesn´t that mean that the avchd encoder is always running all modes simultaneously and the menu´s setting only decides which version gets written to SDHC?
No, the H and L settings do not affect FHD or SH modes, and the 720 60p->30p SH mode setting does not affect the FHD mode. There are, however, numerous technical stabilization settings that affect all video modes, and it's these settings that force the Max Latitude Patch to set SH mode to 30p in NTSC and 25p in PAL modes.
Just been trying this patch out.
The very handy MediaInfo program (on Windows) provides quick details about all kinds of video clips. MediaInfo is telling me that my mts clips (using this 100Mbps patch) have a "Maximum Bitrate 108 Mbps." I'm not sure if that is because some part of the clip is hitting this maximum, or if there's some flag in the mts file that states the maximum of 108, whether it's ever reached or not. MediaInfo also tells me that my "First Video Stream" is anywhere from 1 Mbps to 17 Mbps...but never anything like 108 Mbps. I'm not sure what First video Stream is, but perhaps it's the first few frames out of the clip, which may be lower bitrate due to lack of details. Presumably as the clip progresses, and the image becomes more detailed, the bitrate rises?
ah, allright. thanks!
As you surmised, the 108Mbps figure that MediaInfo reports is metadata recorded in the file header by the AVCHD encoder. This tells the decoder in advance the maximum bitrate it must be prepared to decode. In practice, I have only rarely seen peak bitrates exceed 100Mbps in test files I've shot with the Max Latitude Patch. The 1-17Mbps readings are running average bitrates, which can range up to 40-50Mbps. The GH1's AVCHD encoder begins each clip with a key frame encoded with a low bitrate which then increases over time, and varies depending on the complexity of the subject matter.
If you're interested to examine a detailed frame-to-frame analysis of the GH1's AVCHD files, I highly recommend cbrandin's GH1 StreamParser.
Hi, I would like to have the option to do slowmotion at 50fps.
The 50p-25p Hack, does it affect the H-Mode too? Are all 720p clips then 25p?
If yes, couldn't I just delete the 50p to 25p patch and then record only in H-Mode, where the Bitrates are low enough for 50p?
@plasmasmp
It would be great to see a comparison between the gh2 and the gh13 after grading.
the gh13-footage does look more washed out which is good for grading in post, while the gh2-footage does look good right out of the cam.
it would be interesting to see if after the grading the shadow parts of the image does look better.
right now i can't compare the two different images...
i'm running the Blackout-Powell Native 24p Patch as i wanted to maintain the 50fps for slow motion too & its working out great!
i changed the 1080p GOP length to 15, this seems to work better for us 25p PAL users :smile:
Here is a video I shot with the new patch, so far I'm liking it a lot thanks so much for this lpowell and all the hard work you and others have put into this.
There is even a grass torture test, kind of, at the end where I did manage to get it to crash.
http://vimeo.com/23953786
Max Latitude Music
Max Latitude Music
Hi Mr P,
It was raining so I had to wait a day. I quite fancied filming my guitar and then thought I'd make it a ceremony and take my headdress. At my local park there were a bunch of people playing a game with a pirate flag:happy:
So I played The Game.
Your patch seems to work fine although I didn't have a 'bush of death' at hand. I uploaded the original from Sony Vegas but I think I put the bitrate up too much as the file it rendered was 1.8gb for 5 mins. :cheesy:
If you have pets you may want to put them out of the room. I left all clips untouched. I could have put the brightness up in the last one but it went weird on the preview so I didn't. I now think it may have just been the preview that was weird rather than footage as the footage is mint. 3rd go at editing and recording ever so may look a bit rough.
It's based on this article http://www.rollingstone.com/politics/news/the-great-american-bubble-machine-20100405
Also plays in camera so far.
Mr P, why is it called Max latitude?
If there a way I can stress it for you let me know. Recorded on 30mb/s extreme
I LOVE 24k's video, really really very very good thang there. Absolutely brilliantly simple and looks like looks could kill! Hats(headress) off to you mista.
And now for something completely different:
I have been doing some tests with this patch, and although the results are truly brilliant and no crashes yet, I have run into a software problem that I hope someone can address: neither files from this patch nor from the other 25p ("sexy thread") seem to agree with CS5.
What is the workflow in editing these files for other people. How do you edit?
I do have a Blackmagic-Decklink-Extreme card on this system, the Blackmagic cards can be quirky, but even in a "normal" CS5 project the playback is rather impossible.
Would be very grateful for feedback on this one... and will post today's shots later on.
Transcode to a lossless 4:2:2 codec like Avid DNxHD first.
