100Mbps Max Latitude Native 24/25p Patch
Not working with 32gb class 10 transcend. Testing with 16gb class 10 transcend tomorrow, and sandisk extreme 30mbps 16gb card when it arrives next week.
I had not patched my GH13 for since August. Yesterday finally patched it with lpowell's Max-latitude 100mbps one and took it for a school concert. My observations:
1. This is on Sandisk class 10, 16 gb card. This card has not given me beyond 40-42 Mbps before on hand rolled patch.
2. After the lpowell patch, the average mbps is about 32-37 Mbps for scenes not having too much details.
3. Compared to a previous shooting of a similar occasion with an un-hacked camera, there is very big difference in quality of the footage.
4. The last update for the 14-140 lens seem to have helped the focus speed and seem to have reduced the focus hunt.
5. What impressed me the most was when I shot two kids under spot light. The surroundings were pitch black with well lit subjects (kids) occupying about 40 percentage the frame. The dark areas looked pitch dark when viewed on my Panasonic plasma without any noise or FPN, reminiscent of how concert blurays looks. The ISO was 800. I need to pixel peep again to make sure I am not exaggerating or to see my eyesight has not worsened.
6. The camera gave card write error once and I do not think there were any scenes that would have crossed 45 Mbps. I suspect my card is unlikely to handle more than 45 Mbps regardless of the scene details. I need to recheck by shooting in daylight with some detailed scenes.
7. I did not try to shoot long clips.
Just to share some thoughts and to make it a point to thank both lpowell and Vitaliy enough for their continuing hard work on this cameras. People normally lose steams once novelty wears off, but these people seem to find inspiration and time to do this thankless job even now. I cannot thank you people and those who have contributed by testing etc. enough..:nads:
Has anyone noticed that VLC Player no longer plays the video files back?
The latest update of VLC coincided with the first footage I shot with the new patch, so that could also be to blame.
Yea i had to go back to an older version to get that to play, the last update of VLC don't work with these MTS files on my mac.
I have a PC also and Windows media player Plays High Bitrates videos better than VLC for some reason but since my mac is my main tool i am wondering if there is a Program better than VLC for mac that will read files like MKV and MTS.
Any suggestions?
Thanks in advance.
OK, I have had a chance to test now with a SanDisk UHS-1 Class 15 equivalent 8Gb card. I am still getting lock-ups but at much longer shot times. Seems to depend on whether the camera is totally locked-off or not as even slight camera movement seems to prolong the shot before the cam crashes - this is more important than fine detail in the frame or exposure settings. As most of my footage is shot in locked-off mode at various focal lengths it means that I am not happy using this patch as I never know the minute (or second!) that the cam will crash. It's also unfortunate that the crashed files are deleted in cam so you loose the portion of the shot up to the crash as well. If I'm trying to get a 30s shot and the cam crashes at 27s then I loose everything (rather than just the last 3 secs of the shot).
I agree that the bitrate is considerably higher than the "Reliable" patch I have been using, and it constantly hovers around the 35-40Mbps, but constant (or fear of) crashes just won't justify its use for me. But good luck to anyone who can get it to work for them. All the best.
If you have the camera fixed on a detailed scene - if you put your hand over the lens for a couple of seconds (you don't have to touch the lens) when first recording, then remove it - you can get longer recording times without crashing.
I've tried this and it makes no difference - I think that only works of you crash within 2 seconds of hitting the record button. I'm getting upwards of 20 - 40 seconds before the cam crashes.
Be certain to use the camera to format the SD card before using it record video.
Yes, I always do this - I even formatted after the cam crashed and it left some phantom files on the card. Unfortuantely this patch is just too unreliable for me to use.
Well i've just done further extensive testing on this patch (about 100 clips) with various lens, settings. etc and only one failure, a locked off shot on very detailed grasses. However with the hand over lens technique, it passed. This patch is almost as reliable as the reliable patch.
If anyone doubts the combination of Canon FD 50mm f1.4 and the Max Lat V2 patch, then check this clip. It's handheld, detailed, smooth and creamy in a sharp way. No mud in the dark areas or shadows.
Straight from the camera, no cc or transcoding, shot at f4. The original mts can be downloaded from Vimeo. This is a nice combination of lens and patch. Watch it full Screen at vimeo in 1080p HD
Thanks for posting the clips..
What's the maximum bitrate that you got? Where you able to salvage the footage when camera failed to record?
The Max was 48 the Average was 16. Surprized??? I was waiting for someone to ask. This just proves you don't need huge numbers to get great looking footage unless the there is lot's of birrate robbing details in the frame. The Max number was mainly I frames the P frames were quite low (between 9Mbps and 23Mbps).
No, the one failure out of 100 clips that failed was not recoverable (0Kb).
Here's a little exercise, using Media Player Classic video player, switch to double size and watch it in faux 4k resolution, Hard to fault.
thanks for the patch, lpowell. i am trying to re-install the firmware on my gh1 because i don't think i did it right the first time (i don't think i pressed the A button in ptool after i opened it - if that was necessary).
another question - about the v2 max latitude, is it going to run on ptool 3.56 or should i use version 3.55 instead? thanks.
Vitaliy released an updated PTool v3.56d on Jun 12, which should continue to work with all existing INI patch files just as v3.55d did. I've tested PTool v3.56, using it to produce Version 2 of my Fast Action 3-Frame GOP Patch for the GF1 and G2, and it worked flawlessly for that purpose.
I've just shot a couple of days out in forestry with dappled light and wild tussock grasslands using this patch in harsh winter light. The conditions were EXTREME. The footage looks fantastic. I was using transcend 32GB class 10 cards. Previously, when shooting this kind of footage I had to use the 40 reliable and the interlacing just aliased all the fine details... When using a 50MB progressive patch, I'd have speed write errors on about 40% of my shots over a minute in length, and about 80% of my static shots. The last two days, using the 100MB patch, I've lost ZERO clips. Thank you lpowell!
