http://www.vimeo.com/27043259
The question is: Can the mjpeg patch hold a candle to the native 1024p24 avchd mode, which is indeed very good? Because the official name of the patch is "100Mbps GH2 LOW LIGHT MJPEG 1080p Patch" I´ve shot mainly lowlight footage last night. Feel free to download the mp4 file and form your own opinion...
The first scene is always 1080p24 avchd, the second one 1080p30 mjpeg. At the side-by-side comparison the left one is avchd.
Nikon 50/1.4 (lowlight)
Kit Lens 14-140 (daylight)
All night shots at f1.4, shutter 1/50 and iso 800
Currrently it seems that there is a fault with the patched audio. It captures the sound always with a gap in-between... like 2 seconds sound, 2 seconds nothing, 2 second sound.... and so on. Hopefully lpowell can fix it. And the other downside for me was that I can´t preview the files in the camera with the lpowell patch. I always get a read error. Maybe my 16gb transcend class 10 card is too slow..
Music: Solar Sailer by Daft Punk
Any chance of getting a 1080P download of this?
GH2 cracks 100Mbps in MJPEG HD video mode @ 1920x1080p!
The 100Mbps GH2 Low Light MJPEG 1080p Patch will not work properly with previous versions of PTool. My thanks once again go to Vitaliy Kiselev, for his pioneering work on PTool, and to cbrandin for his invaluable Stream Parser tool.
The best way to insure that you have the latest PTool release is to download it directly from the following link:
Download PTool here: http://www.gh1-hack.info/ptool3d.zip
100Mbps GH2 Low Light MJPEG 1080p Patch Settings File:
This zipped INI file can be used to apply complete patch settings to firmware loaded into PTool. To use, unzip the INI file into the same folder as the PTool application. Launch PTool and load the firmware for GH2 v1.0. The settings contained in the INI file will automatically be installed in the "C" button at the bottom of the PTool main window.
Note that with the following PTool Settings File, you may at any time re-install the original Panasonic GH2 v1.0 firmware into the camera. You may also copy each type of patched or original firmware to separate SD cards, and use them to quickly switch between patches as often as you like.View attachment 37293
If MJPEG's 30p frame rate is acceptable and you need a precise color key, then yes, the GH1's 4:2:2 color space can improve the quality of your post-production work. Otherwise, I'd prefer the GH2's efficient B-framed AVCHD encoder.So for general production shooting (ie: green screen aside), do you think the quality advantage of the 4:2:2 GH1 colour space would outweigh the imagery advantages of the high bit 4:2:0 GH2?
