What do you use for screen protection? The LCD screen is razor-sharp, high-quality LCD. Can't find a screen protector that fits exactly...
I purchased this camcorder this morning. I will be on a long assignment and I’m going to need a workhorse camera. My main camera is an FX6, but this should be better for the run and gun content we’ll be producing. Going to do some tests and see if it’s a good fit. If not I’ll return and stick to the 6 for now.
As a fellow FX6 owner who occasionally is tempted by a camcorder for certain types of work I'm very curious to see what your final thoughts are!
Can you try one of your existing lanc controllers 2.5mm zoom connection that works with the HC-X1 in the 2.5mm input on the HC-X2. I think the zoom function should work.
The old style Varizoom for Panasonic controller 2.5mm like this
https://www.bhphotovideo.com/c/product/330081-REG/VariZoom_VZ_ROCK_DVX_VZRockDVX_Zoom_Control.html
will plug in but will not work in X2 with zoom or record. Works in X1.
The Varizoom for Sony Lanc controller like this
https://www.bhphotovideo.com/c/prod...m_vzrl100_zoom_record_rocker_control_for.html
works in X2
Must be different protocol. This seems to indicate all old style panasonic controller will have to be replaced. Hope this helps
I seem to recall a discussion about this with the CX350. they've apparently moved away from the controllers we've been using since the DVX100 days
Some more info to add that might be useful:
It can do the super fast variable zoom like the UX180/HC-X1 but seems to have to be assigned to a user button to activate it, else it will variable zoom slow to a reasonably fast zoom, but certainly not a crash zoom *unless* you activate it.
It can no longer record DCI 4K at all, only UHD 4K
Lens is 24.5mm not 24 as before
Color is certainly different from before (looka better/more natural) so won't match X1 via factory presets ...unless tweaking it might?
LCD screen is WAY better than before
Can't do AVCHD in 30p anymore (29.98) but can do 24P and 60P
Facetracking seems to only work in FULL AUTO everything mode which is crazy.
Can still record in some H.264 .mov formats 4:2:0 and 4:2:2 that work in older software such as CS6.
Dual codec record seems limited to UHD 30P with HD 30P as before, at least in H264 modes
I will definitely follow up then. I love the 6 for everything, I even got a gratical eye for Eng work, but having a single lens and not having to build it out each time I travel is really priceless. I will still take the A7siii for gimbal work and maybe stand ups for the extra DR. I definitely want to see how much DR it will give me with a standard profile. Like an S cinetone equivalent which is a custom profile, but gives you a little more DR than 709.
Thanks of the update. I do have several of the old controllers but the second one you linked to is very reasonably priced.
This is unacceptable. I haven’t received mine yet but I read some of the manual. It shows that there is an AF only switch, but when it talks about face tracking it shows AF/AE. Is there no way to shut off the AE portion in the menu somewhere? If not this is something they need to add via firmware because it’s insane in 2022.
Yes, it is a stupid limitation. I definitively would use facetracking but not in FULL AUTO MODE. So now, I'm stuck at zone AF.
Apparently there is a way to disable the auto exposure linking to the face AF. It comes from the factory with it enabled unfortunately.
Good point. Lens is not Leica like the CX350, but no sure how that impacts picture quality or not. I've have assigned crash zoom to a USER button. Really useful. I guess that is disabled by default in order to save battery, maybe..
