No more personal attacks please. If you can't play nice find another thread.
SX1 or GH-1? Neither...although I have been chatting with people who have it and looking at lots of clips. When I started I was looking at the EX3, EX1, HPX170, HMC150. Looking harder, none are interesting any longer.
However, the SX1 probably sets the low end of what should be considered acceptable. '
I have another GH-1 question: is it limited to 4GB FAT32 files or does it have a mechansim for continuous recording?
That doesn't seem sensible. That's because the GH-1 is sharper than the MK II?
I don't see any changes being made to the 1080i/60i 24P Capture nor the Bitrate... =T Surprises maybe?
Not sure this is right, but I tried running some DOF calculations. It looks like the GH1 offers shallower DOF than the 5D:
With a 40mm lens, f1.7, and subject distance of 10 feet:
Model: DOF, Range of acceptable sharpness in feet
5D: 1.91, 9.13-11
GH1: 0.95 9.55-10.5
40mm lens, f1.7, subject distance of 4 feet:
5D: 0.3, 3.86 - 4.15
GH1: 0.15, 3.93- 4.08
20mm lens, f1.7, subject of 10 feet:
5D: 8.94, 7.24-16.2
GH1: 3.96, 8.4-12.4
20mm lens, f1.7, subject 4 feet:
5D: 1.24, 3.47-4.71
GH1: 0.61, 3.72-4.33
Calculations from: http://www.dofmaster.com/dofjs.html
I don't believe this is accurate either. According to specs the cam captures 24p in a 60i container. So I believe there is pulldown added. The 60p options are fully progressive though. (720p).Its 1080/24p or 720/60p in AVCHD or 720/30p in MJPEG. No interlaced option, thank god.
The point is: when using (in the 5D Mark II's movie mode) every pixel on every third row -- AFAIK it ain't skipping every 2nd pixel (horizontal and vertical) but sampling only one out of 3 pixels (horizontal not vertical), the resolution drops to 1/3rd. Being the full resolution (sensor) in movie mode (before downsizing to 1920x1080) 5.9MP instead.I don't think the Canon is throwing out 75% of the pixels. The interpixel gaps would be so huge as to have other artifacts. Also, it would lose its low light advantage, which is clearly not the case.
It does throw away 19% of the pixels, since 16x9 can only use 3159 rows.
The nanoFlash XDR is nice and most important portable, but expensive at $3500 and using MPEG2. Still 3x the bandwidth of a similar protocol XDCAM EX. And records I-frames at 160Mb/s.
Blackmagic Designs Intensity to a computer is $250-350 and Cineform is $500-750 (to capture directly). My guess is Cineform will also store a somewhat better image. To make Cineform portable you'd needs a battery powered PCIe to ExpressCard expansion chassis (I only know of a plug in model for $750 and a laptop with two disks and a fast processor...someplace between $1000 and $2000. Not that much different than the nanoFlash XDR. Then, they aren't shipping the nanoFlash XDR.
The advantage of 10-bit storage of an 8-bit signal is for accuracy in editing. Is 2/3 1, 0.7, or 0.67?
